Old Feb 07, 2002, 01:48 AM
DEATHspiral is offline
Find More Posts by DEATHspiral
San Diego, CA, USA
Joined May 2001
amp draw twin sp400 4.8v?
Someone help me please, if you have motorcalc, or prior experience.
What is the amp draw from twin sp400 4.8v, running on 12cell, and on zagi props?
thank you in advance
DEATHspiral is offline Find More Posts by DEATHspiral
Old Feb 07, 2002, 09:26 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
I hope you have them connected in series. That's equivalent to one S400 4.8V on 6 cells. Even that will be around 20A, maybe more.
Parallel connection would be ridiculous. The smoke would come out of the motors in about 5 seconds.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Feb 07, 2002, 11:21 AM
San Diego, CA, USA
Joined May 2001
i have the motors connected parallel, and i'm planning to use a 12cell pack. So pretty much do you think, the motors will melt down, or the speed controller will? I'm using the wattage ic550.
Old Feb 07, 2002, 11:25 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I have a twin EDF (Red Flame Blasters) using 4.8v (wired in parallel) s400's on 7 cells, current draw at full throttle is about 23 amps, combined.
With 8 cells these motors draw 13 amps (Robert Wagoner of EFI).
On 8 cells my 4.8 S400 lasted all of 35 flights
Extrapolating from this info one might expect 20 amps each.
I disagree with Steve. The smoke would start in 4 seconds
Larry Dudeck is offline Find More Posts by Larry Dudeck
Need thrust/rpm/amp draw of this sp400 combo Niggo Power Systems 6 Sep 28, 2005 03:18 PM
Pros & Cons of 4.8V 6.0V and 7.2V S400 DerekB Foamies (Kits) 12 Feb 25, 2002 06:19 PM
AMP DRAW twin4.8v sp400? DEATHspiral Foamies (Kits) 4 Feb 08, 2002 05:17 PM
Speed 400 4.8V & Speed 400 Rocket? squelchF18 Electric Plane Talk 3 Jan 08, 2002 08:37 PM
Approx. AMP draw for two Sp400 6V on 8 cells?? fw-190 Electric Plane Talk 13 Jun 25, 2001 09:47 AM
