Old Sep 27, 2014, 03:37 PM
Bruno Stachel is offline
Find More Posts by Bruno Stachel
Bruno Stachel's Avatar
Edgewood, KY (Cincinnati)
Joined Jan 2004
Something I didn't think was done in 1:1
I thought the free flight guys would like to see this.
Bruno Stachel is offline Find More Posts by Bruno Stachel
Old Sep 27, 2014, 03:39 PM
Joined Jan 2004
It's on a replica of a Nieuport 28.
Old Sep 27, 2014, 07:25 PM
baldguy is offline
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
That's done a lot on some full size aircraft, especially those without cockpit adjustable trim tabs.
baldguy is offline Find More Posts by baldguy
Old Sep 28, 2014, 04:40 AM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Would it be too troublesome to re-string the control cables to incorporate that trim change? The tab doesn't look very pretty.
Trisquire is offline Find More Posts by Trisquire
Old Sep 28, 2014, 11:20 AM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
If One were to "re-string" the control cables, all it would do is change the stick position in the cockpit. The trim tab was added to relieve some of the control pressures on the pilot's hand, and arm.
However, One [I]could[I] shim the horizontal stab to perform the same task.
challenger_i is offline Find More Posts by challenger_i
Old Sep 28, 2014, 06:16 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
Actually, it's done all the time 1:1.
packardpursuit is offline Find More Posts by packardpursuit
Old Sep 28, 2014, 07:00 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Hers one on a Hurricane, this is in addition to a Trim Tab.
Does than make this a boost tab?
1320fastback is offline Find More Posts by 1320fastback
Old Sep 28, 2014, 10:38 PM
Joined Jan 2009
Might Google "trim tab", "adjustable trim tab", "servo tab", "anti-servo tab", "spring tab" and "balance tab". Boost tab is sometimes used to describe a direct mechanically connected servo tab, which aids in moving the surface in the desired direction. In 1920'-30's large British aircraft oft had servo tabs connected directly to the pilot's controls, which moved the larger, unconnected, surfaces to control the aircraft.
The Hurricane appears to have a "fixed, ground adjustable trim tab" next to the adjustable elevator trim tab. IIRC, there is a pair on the opposite elevator as well.
Mustangs (P-51B/C/D/K) with Dorsal Fin Fillet, have had anti-boost or anti-servo function added to the rudder trim system. This increased the force required to move the rudder, but trim was still adjustable. IIRC, F4-U's have elevator boost AND balance tabs!!?? That simple tab can have some complex iterations!
Old Sep 29, 2014, 12:34 AM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
So what would they have done with that Nieuport back in WWI? The pilot would have just dealt with uneven control pressures? I thought the purpose of a trim tab was to put the stick's neutral position where it should be - at neutral.
Old Sep 29, 2014, 03:32 AM
Kiwi is offline
Find More Posts by Kiwi
New Zealand, Otago, Harwood
Joined Sep 2004
Back in the day instead of attaching a tab, a length of cord would be doped along the trailing edge, the length varied according to the amount of trim required, the cord was usually covered with a piece of fabric doped over to hold it in place.
Kiwi is offline Find More Posts by Kiwi
Old Sep 29, 2014, 09:06 AM
Balsabird is offline
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
Kiwi--we did that to our Travelair 4000 biplanes at a flightseeing company I flew for. Both required more trim travel than was available (always had to hold a little forward stick), so a 3/8" triangular strip was taped onto the elevator trailing edge, adjusted in length and flown until it flew level with the trim centered in neutral. Each required a different-length strip. Once we had it where we needed it, the strip was glued down with fabric cement and some 3" surface tape was applied, then doped to match. That way, the limited amount of trim travel available could be used, and the airplane flew level.
For what it's worth, Travelair biplanes had a trimmable tail, not a trim tab.
Balsabird is offline Find More Posts by Balsabird
Old Sep 29, 2014, 10:51 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Tampere, Finland
Joined Nov 2004
Pitts S1 photographed in the summer of 2012. The owner said he and previous owner(s) have gone for simplicity and keeping the weight down, instead of adding power and weight for performance.
The aircraft was 40 years old then, and had recently been through a thorough overhaul.
perttime is offline Find More Posts by perttime
Old Sep 29, 2014, 04:36 PM
Joined Jan 2009
Not sure of the specific rigging limits possible on Nieuport 28, however most WWI types could be fine tuned in stagger, wing incidence, to adjust for fore and aft trim, wing heaviness etc.
Same can often be accomplished, within reason, with a trim tab on a convenient/proper surface.
When I was kid (1960's), my father owned a Travel Air 4000, with trim tab in one elevator. It had been a "rice seeder", in a previous incarnation.
Old Sep 30, 2014, 06:30 PM
baldguy is offline
I eat glue
Joined Jul 2006
A lot of the early aircraft were ground trimmed or tuned for level flight at a normal cruise throttle setting. Any changes in throttle change meant that they either had to hold back or push forward on the stick.
The RCAF Snow Birds fly with the trims set so that they have to constantly pull back on the stick.
Old Oct 09, 2014, 02:06 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
You can see one tab and a little bit of another on the Facetmobile:
http://www.mfhb.org.nz/joomla/images.../Facet%202.jpg
Barnaby Wainfan, its designer, said that until they added up tabs and a down bungee, the control forces were reversed. Not something that showed up when testing the RC model.
lincoln is offline Find More Posts by lincoln
Discussion Nano-T Rx. Have I done something wrong? tagasagwan Xtreme Power Systems 66 Nov 11, 2013 10:53 AM
Gallery 1/4 + scale curtiss jenny with german machine guns, I know What was he thinking! michael quillan Giant Scale Airplanes 0 Sep 26, 2013 08:42 PM
Discussion I bent something I didn't think I'd ever bend Aznisegi Electric Plane Talk 6 Jul 02, 2008 07:54 AM
I didn't think this was possible... Engineer3386 Electric Plane Talk 13 Sep 29, 2005 11:43 AM
