Old Apr 07, 2015, 09:49 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Originally Posted by Montag DP View Post
Paul,
I haven't done that. But, I don't really see the need either. Since you can already specify the Reynolds number, Cl, and Mach number for every operating point, you can just set up your operating points so that Re*sqrt(Cl) is constant, with the value determined based on the model weight, altitude, etc.
Dan
Yes but you can only choose one of the following for all Re : "min-drag" or "min-sink" and "max-glide".
e.g. if I want min-sink at low Reynolds (thermalling) and max-glide at high Reynolds (to get through sinking air between two thermals).
Have you read Martin Simons series of articles on RC soaring here:
http://www.rcsoaringdigest.com/pdfs/Simons_UTSS.pdf
I suppose you have.
Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Apr 07, 2015, 11:25 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
United States, GA, Atlanta
Joined Apr 2005
I suppose you have.
Paul
Paul,
Here's how I would handle that problem. You can let me know if I'm being dense. In either of those cases (thermalling or flying between thermals), the lift is going to be known, so you can compute the Cl based on the flight speed and wing planform. Then compute the Reynolds number and Mach number as well for that flight condition. Finally, optimize the airfoil for 'min-drag' at each of these operating points. The reason being that if Cl is specified, all three types of optimization amount to minimizing the drag, even though the objective function may be computed differently.
Dan
Montag DP is offline Find More Posts by Montag DP
Old Apr 07, 2015, 12:06 PM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Paul,
Dan
Thanks Dan,
I'll think about it and give it a try tomorrow.
Regards,
Paul
Old Apr 09, 2015, 11:57 PM
carvegybe is offline
Find More Posts by carvegybe
Joined Mar 2015
Everyone,
I've uploaded a new version which includes a constraint to generate symmetrical airfoils....
Thanks for that, I'll give it a spin tonight.
carvegybe is offline Find More Posts by carvegybe
Old Apr 10, 2015, 01:30 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Well, it didn't work. But don't bother Dan.
Old Apr 10, 2015, 01:57 AM
Geoff_S is offline
Find More Posts by Geoff_S
Geoff_S's Avatar
Brisbane, Australia
Joined Feb 2002
Dan, I'll admit I was a bit confused by the choice of "min-drag" or "min-sink" and "max-glide".
Since the analysis is being performed on a 2D aerofoil, and not a complete wing, I couldn't see how you could calculate min sink or max glide conditions ?
And isn't the min-drag optimisation being performed for each operating point independently, with the penalty functions and weights being used to determine the overall optimal aerofoil ?
Geoff_S is offline Find More Posts by Geoff_S
Discussion Airfoil Optimization Using Genetic Algorithms Ghost_ Modeling Science 38 Apr 24, 2014 06:18 AM
Discussion Airfoil Optimization with XFOIL Montag DP Modeling Science 168 Feb 03, 2014 08:14 PM
Discussion Evolutionary airfoil design optimizer available kcaldwel Modeling Science 3 Dec 10, 2012 04:03 PM
Profili - Xfoil and reflexed / autostabilizing airfoils surfimp Modeling Science 29 Mar 30, 2005 06:32 AM
