Old Nov 05, 2013, 08:59 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Viper Q500 Wing servo Mod mount
Doing the mods to A Viper that was bought from a guy that had assembled it but I don't think he ever flew it. I wanted to show the wing servo mount because the way the manufacturer has you put it in, it will fail or hang up on something inside the Fuse. Before
Description:
Dale 813 is offline Find More Posts by Dale 813
Old Nov 05, 2013, 09:00 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
After
Description:
In the first pic. Is a standard size servo. With a big swing arm. Way too big. Especially for racing.
Old Nov 05, 2013, 11:55 PM
bigblueswope is offline
Find More Posts by bigblueswope
bigblueswope's Avatar
United States, GA, Loganville
Joined Aug 2012
What's the servo in the second pic? Standard size?
bigblueswope is offline Find More Posts by bigblueswope
Old Nov 06, 2013, 05:35 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
No. It's a Hitec 225BB mighty Mini servo. http://www3.towerhobbies.com/cgi-bin...&I=LXN664&P=ML
The servo in the first pic is a Futaba 3003
The Hitec 225BB or the 225MG are very good servos and are used by most in Quickies and Club 40 Planes. I know for a fact that the #1 Club 40 Pilot in Florida uses the 225BB's there only $17.99
Old Nov 06, 2013, 05:45 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
In order to achieve what I did. You'll have to cut out slots for the wood blocks to fit into. Also have to cut out one layer of wood on the bottom where the servo sits. When you first start cutting away wood for the wood blocks. It would seem that there's not a lot of wood material for the epoxy to hold onto. You will also be into the foam which is no biggie. No worries. Just add a liberal amount of epoxy amd lay the wood block that sits closest to the leading edge. Let dry. Then do the other one installing the servo at the same time with the servo shaft closest to the trailing edge. Need to have a good Z bender. . Makes a perfect fit.
Also. Don't use the long servo arms. Use the wheel. And mount the push rods to the hole on each side that's closet to the leading edge of the wing. This helps with differential. Adverse yaw in the turns. Also limits anything binding up in the fuse. I'll post a pic later of where i mount the throttle servo. It not the same as Viper does it.
Old Nov 06, 2013, 07:40 AM
Joined Aug 2012
thanks for the tip
Old Nov 06, 2013, 07:55 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Throttle servo location
Description:
Discussion Q500 Viper Tail Mod reinforcement Dale 813 Pylon Racing 5 Oct 18, 2013 05:13 PM
For Sale Q500 Viper Race Ready 424 Dale 813 Aircraft - Fuel - Airplanes (FS/W) 1 Oct 13, 2013 10:50 PM
For Sale Great Planes Q500 Viper Dale 813 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 01, 2013 01:01 PM
Question ARF or RTC Q500 Viper ?? Dale 813 Pylon Racing 5 Feb 22, 2013 11:53 PM
FS. Q500 RTF, Q500 RTC, Kaos 40 wing, Falcon or Skylark 56 wing, other wing. harikay Aircraft - Fuel - Airplanes (FS/W) 14 Jan 25, 2005 06:46 PM
