Old Oct 11, 2013, 03:44 PM
Cona is offline
Find More Posts by Cona
Joined Oct 2013
Sickle wingspan reduction need help with the spar
Hey there:
I am building 3 sickle spads that were origionally 35 inches. I bought it off of ebay about 5 years ago as a shark models shark not sickle but its the same but only 35 inches. So if I am useing 4 inch downspout how do I make the spar?
Any help please as they are almost done but finishing the wings and I want to get it right ya digg?
Thanks again
Cona
Cona is offline Find More Posts by Cona
Old Oct 11, 2013, 04:37 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
4" downspout is pretty big stuff. I would make a full wing, and cut out the fuse to fit, instead of notching the wing. It would likely save a bit of weight, or at least give more strength to the wing. The fuselage should be strong enough if it is 4". Kind of like the pic, although it is a different plane, and only the 2 1/2" downspout.
aspeed is offline Find More Posts by aspeed
Old Oct 11, 2013, 08:09 PM
Cona is offline
Joined Oct 2013
Im pretty sure its 4 inch like the origional sickle. The differance is just the wing span and spar length. I have the origional wing but the spar is missing...the glue is still marking where it was. Its a 35 1/2 inch wing with a 34 inch spar. I need to know how to cut the 2 yardsticks that are used. Ive seen sickle plans with a flat bottom spar and one that is symetricle but none that are 35 inches wing span.
There must be some calculater somewhere? I just want these to fly. I will finish 1 and tune it then build the other 2. The fuselages are done already and I have the radios and 25fx ready to fly....shagrin!
Old Oct 12, 2013, 04:05 AM
Cona is offline
Joined Oct 2013
I still need a hand with the spar if someone knows how to make these. And I did measure the downspout and you were right its 2.5 inch. The spar was 34 inches and the wing is 35. and the downspout is 2.5. If anyone has instructions for a spar like this please point the way to them. I think the origional 35 inch shark/sickle had a symetrickle wing but Im not sure. The spar was lost a few years ago. The sickle with the
Thanks again
Cona
Old Oct 12, 2013, 10:55 AM
Cona is offline
Joined Oct 2013
Bumparoo still scratchin my head
Help!
Old Oct 12, 2013, 11:33 AM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
http://www.spadtothebone.net/SPAD/ The plan may be on here. I think the bottom is tapered to give the slight dihedral. It is likely in one piece because of the short span, nothing needs to be joined. I assume you were the one in the other forum.
Old Oct 12, 2013, 12:25 PM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
This?
Extreme Sports is offline Find More Posts by Extreme Sports
Old Oct 12, 2013, 12:31 PM
Cona is offline
Joined Oct 2013
Yep that was me also.
Discussion SPAD "the sickle" with brushless engine. Creative78 SPAD - Simple Plastic Airplane Designs 0 Jul 08, 2013 01:16 PM
Discussion need help with choosing wich esc to match a simon k rc timer pls help quadcopterguy Multirotor Electronics 2 Jun 09, 2013 09:11 PM
Help! HELP!!! Tarot FY680 Build - Need help with parts! Yo_Mang Multirotor Talk 5 Apr 13, 2013 08:40 PM
Help! NEED HELP with TRACE OSD WIRING with Gopro Camera - Diagram Included v00d0o FPV Equipment 3 Mar 10, 2013 04:54 PM
Discussion Need help with setup for guillow's 16 inch wingspan Nevped67 Scratchbuilt Indoor and Micro Models 4 Jul 05, 2011 02:01 PM
