Old Sep 11, 2013, 04:19 PM
tincanrider is offline
Find More Posts by tincanrider
United States, CA, Tehachapi
Joined Aug 2009
Question
Prop shafts
Due to shaft angle some elect. motors end up sitting high in the hull and angled, I have seen a set up where the builder used two "U" joints with a short shaft between the motor and prop shaft. When I worked on full size motors & pumps etc. we had to maintain .004 axcial aliment between motor and shaft so has any one elese used the two "U" joint and shafts set up to lower motor in the hull, was thinking of trying this in a 1/20 scale PT boat.
Thanks, Keith
tincanrider is offline Find More Posts by tincanrider
Old Sep 11, 2013, 06:09 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
TCR: Double u-joints is what ALLOWS you to run with significant misalignments. Does anyone hold 4-thou alignment between their trans and rear axle? Nope, they're connected with an intermediate shaft and double u-joints.
I do this all the time, including in my triple motor 1:20 PT:
http://matthewsmodelmarine.wordpress...e-expendables/
BTW, the much loved Dumas dogbone is essentially a short intermediate shaft with double u-joints. I will cut them in half, and jam them into a piece of tube to make a longer shaft. The PT, again:
http://www.rcgroups.com/forums/showt...9#post20897597
BTW #2: Don't try to do it with a single u-joint. This COULD allow motor and prop shaft centerlines to be angularly misaligned, but their centerlines have to intersect exactly, and in the middle of the u-joint. Double u-joints allows for offset and angular misalignment.
patmat2350 is offline Find More Posts by patmat2350
Old Sep 11, 2013, 08:17 PM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Something I haven't seen in the hobby world is a double cardan shaft....
They are out there..just not in a bolt on unit..
more coffee is offline Find More Posts by more coffee
Old Sep 11, 2013, 08:53 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
My choice, like Pat said, is Dumas. They just work!! Here is a Photo.
CaptCB is offline Find More Posts by CaptCB
Old Sep 11, 2013, 09:30 PM
Cheif Bottlewasher
Joined Sep 2005
No argument there.
Old Sep 11, 2013, 09:32 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
All day long:
http://www.harbormodels.com/site08/m...propulsion.htm
Or just join two of these with as short or long a shaft as you like:
Old Sep 11, 2013, 10:07 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
My problem with these is that they still transfer some load, as they DO NOT, have a true, "floating" center link. ANY, load transfer, ADDS wear.
Old Sep 11, 2013, 10:14 PM
DDWILLIE is offline
Find More Posts by DDWILLIE
United States, MA, Haverhill
Joined Aug 2011
Dumas dogbone couplings
I'm just unlucky I guess. I have a Dumas dog bone that has one of the brass ends drilled approximatly .003 to 005 thousands off center. When I had it in my Dumas utility It vibrated very badly at high RPM. Had to take it out. Like Pat said, they are great if they are made right, if not, look out!!
DDWILLIE
DDWILLIE is offline Find More Posts by DDWILLIE
Old Sep 11, 2013, 10:57 PM
Cheif Bottlewasher
Joined Sep 2005
Originally Posted by patmat2350 View Post
All day long:
touché!!
got me there ..I have a dozen metal ones ,all under sized so I can resize them to what I need later.
My mind got up and left the building!!!
Old Sep 11, 2013, 11:29 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
DDWILLIE
None of mine have been drilled off-center, but some have been very roughly machined.
I feel like Dumas' quality control has slipped in recent years.
ZZ56 is offline Find More Posts by ZZ56
Old Sep 12, 2013, 12:45 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
No argument there, but, still my preferred universal joint system!
Old Sep 13, 2013, 09:09 PM
Mr. Wood is offline
Find More Posts by Mr. Wood
Joined Apr 2009
The plastic stuff wears out down here in Fla. maybe I run my boats too much...
Mr. Wood is offline Find More Posts by Mr. Wood
Old Sep 13, 2013, 11:28 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
I have a Thompson Trawler with a 2 3/4'', 4bld prop, and it has the same Dumas universal joint parts, put in 25+ years, and how many hundreds of hours, of use. We estimate my LCM-6 based tug, has over 800+ hours on it, since built in 1989, and it still has the original Dumas parts in it. My boats are stored, and run, in temps from 40-100+ degrees, so no love there. Where they actual Dumas parts, or one of the many Chinese copies??
Old Sep 14, 2013, 06:22 AM
tghsmith is online now
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
I have "extended" dog-bones in my vesuvius project, strange shaft angles and narrow hull sections, allowed for the motors to be moved much farther forward and reduced the coupler angle from "not going to work" to "nice and quiet" . using vac-u-boat couplers, they have four pins on each end of the dog-bones.. round and smooth the inside machined edges of the brass coupler parts so they don't cut into the dog-bone pins.
tghsmith is online now Find More Posts by tghsmith
For Sale Prop Savers 1.5 mm Motor Shaft to 4 mm Prop Bore scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Apr 14, 2014 10:48 PM
Sold Prop Adapter - 2mm motor shaft to 5mm prop LowWatts Aircraft - Electric - Multirotor (FS/W) 2 Sep 03, 2013 03:03 PM
Sold Vintage 4 Prop Drive System W/Gearbox 4 Shafts, And Props stevster Boats (FS/W) 1 Jun 09, 2013 06:35 PM
Help! How to remove prop shaft - Mini Vapor tyoung560 Micro Ready-to-Fly 6 Feb 10, 2013 12:50 AM
Help! Cowling prop shaft hole enlargement jchtr3a The Builders Workshop 11 Jan 10, 2013 09:52 PM
