Old Feb 03, 2013, 10:05 AM
TexasJohn is offline
Find More Posts by TexasJohn
Stick lift beats no lift
TexasJohn's Avatar
USA, TX, Arlington
Joined Mar 2003
Help!
Need ideas - tools for cutting a hatch in fg fuse
I'm pondering converting a pure glider to electric. Its a beautiful machine and I want to cut a hatch under the wing - in the belly - to move the tail servos back there, leaving the nose and near front of wing for battery, esc and so on.
The hatch would ideally be a smooth oval with absolute minimum kerf. Then I'd glue an inner lip inside and mount semi-permanently.
My notion so far is a tiny router bit and some kind of pattern to attempt to follow - something harder than fg so the bit will sort of follow the pattern.
I have some collets for small drill bits...now I think I need some tiny routers too.
Does anyone have any special suggestions or techniques for the cutting and guiding the cutter? My experience is they wander a lot. I'll start looking for the bits - may even have them at my local Hobby Town.
Here is a link to the glider if you want to see it before I do this really bad thing to it (bad if you are a glider purist!!). http://www.rcgroups.com/forums/showthread.php?t=1808352
Thanks.
TexasJohn is offline Find More Posts by TexasJohn
Old Feb 03, 2013, 10:40 AM
jkettu is online now
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
I'd just cut the hole a little undersize and then sand it to the size and shape needed. Obviously I'd then need to make a new hatch from scratch. Or more likely just patch the hole up after installing the servos, accepting that any maintenance will require surgical operations.
If you decide to have a removable hatch, I'd recommend adding some carbon rovings around the hole to carry bending and twisting loads to the other side of the hole.
jkettu is online now Find More Posts by jkettu
Old Feb 04, 2013, 11:35 AM
kenh3497 is offline
Find More Posts by kenh3497
Live long and fly high
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I have a large assortment of dental drills at home. Some are even carbide! Trying to find or build a pattern will be the tricky part. I assume you wan to save the cutout for the new hatch. It may be easier in the end to just build a new hatch. The time to do that is before you cut your fuse for the access hole. Mark your spot where you want the hole. Lay some saran wrap or other film on the spot and proceed to lay up some glass and epoxy to the thickness you want. Basically you are using the fuse as a mold for your new hatch cover. No need to be neat at this point. After you cut and finish your access hole take the new fiberglass part and trim to fit your hole.
Hope this helps.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 04, 2013, 09:29 PM
TexasJohn's Avatar
USA, TX, Arlington
Joined Mar 2003
I like this. Could even make an extra hatch just in case. Yes I was hoping to use the cutout ....my first choice.
Old Feb 05, 2013, 07:19 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Hope this helps.
Ken
That's the "best" way IMO, it's how most guys make gear doors and access hatches.
Hemikiller is offline Find More Posts by Hemikiller
Old Feb 05, 2013, 08:10 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Something to think about, although it may not be a problem here, is that the fuselage appears to get it's strength from the shape. By cutting a hatch in the fuse will weaken it. Size and position will dictate how much. Just something to think about particularly when adding a motor/battery
FWIW, a flying buddy cut a hatch in a molded fuse quickie 500. A few of us at the field, tried to tell him it was a bad idea due to placement and size. Well a few flights in, the plane told him it was a bad idea by exploding during a turn.
rcav8r2 is offline Find More Posts by rcav8r2
Old Feb 05, 2013, 07:00 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I use a place masking tape along where I want the hatch, draw a cut line in pencil and then very carefully and slowly cut with and Xacto blade.
To make the canopy and lip see here:
Read through post #110
http://www.rcgroups.com/forums/showt...7#post21097972
And here:
http://www.rcgroups.com/forums/showt...5#post17319543
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Feb 05, 2013, 10:50 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Check out this home made hatch cutting tool http://www.rcgroups.com/forums/showp...&postcount=287
Wilfor is offline Find More Posts by Wilfor
Old Feb 08, 2013, 12:03 PM
TexasJohn's Avatar
USA, TX, Arlington
Joined Mar 2003
I thought the inner lip creation was brilliant.
I may have found a simpler solution.
It turns out that LiFe batteries in a line might fit where my ballast used to set...so maybe no need to shift anything around. Now I'm focusing on fitting a motor in there with the nose cone remaining removable. I think it might work with a folding prop if the prop will flip forward and I can bear to cut a big enough chunk off the nose cone to fit over the yoke...not sorted out yet.
Thanks for all the great ideas - I enjoy reading them.
Discussion Looking for FG Fuse ideas Twizter68 Sailplane Talk 9 Jan 22, 2008 04:31 AM
Discussion Cutting hatch on lost foam fuse. JIM CALDWELL A Composites Fabrication 10 Dec 02, 2006 09:26 AM
Question Need ideas for hatch latch WarPoet The Builders Workshop 8 Jan 16, 2006 08:16 PM
in-need indeed...(need fuse. ideas or plans) rmeflyerkid Foamies (Kits) 0 Jun 30, 2004 09:42 PM
which tool for cutting a fiberglass fuse? p471701 Electric Ducted Fan Jet Talk 7 Jun 19, 2001 09:22 PM
