Old Jan 24, 2013, 02:51 PM
JoHowell is offline
Find More Posts by JoHowell
You are building WHAT?
JoHowell's Avatar
Huntsville, AL
Joined Apr 2004
Spektrum DX 18 setup for 4-servo wings
Okay, I'm a newbie with these programmable Tx's. I'm having difficulty making heads or tails about what/how to mix for a 4-servo wing. Model is a Spirit 100 w/ independent servos for ailerons and flaps on each panel. I'm looking for a "plain Jane" configuration that works. If I can get thru that, I figure I'll learn some basics before venturing out and experimenting.
I have gone thru the "Sailplane type" set-up which got me me thru Rx Chanel assignments of
1=>Left Ail
2=>Rt Ail
3=>Ele
4=>Rud
5=>Rt Flap (This appears to me to be the "gear" channel on the Rcvr)
6=>Left Flap (This appears to be the Aux1 channel on the Rcvr)
I worked my way thru servo set-up and mixing as:
Mix 1 Ail>LAL
Mix2 GER>LFL
At this point I get rudder, elevator, and right aileron, and hard deflection on the right flap.
I suspect I'm missing some set-up for transmitter assignments, but I cannot make heads or tails about what needs to be done from the manual.
Has anyone used one of the DX 18's successfully?
TIA,
Jim Howell
JoHowell is offline Find More Posts by JoHowell
Old Jan 24, 2013, 03:40 PM
tkallev is offline
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Try here: http://www.rcgroups.com/forums/showthread.php?t=1671026
tkallev is offline Find More Posts by tkallev
Old Jan 24, 2013, 04:08 PM
JoHowell is offline
JoHowell's Avatar
Huntsville, AL
Joined Apr 2004
Originally Posted by tkallev View Post
Got it, thanks for the vector. I'll see if it gives any clues as to what I'm doing wrong.
Edit: Thank you for the vector! I found Sherman Knight's excellent write-up/guide for what I am trying to do.
Thx,
Jim Howell
Old Jan 24, 2013, 07:16 PM
tkallev is offline
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Good!
Sherman knows his stuff ... my momma always told me not to reinvent the wheel!
Glad to be of help
Question Spektrum DX-8 SD Card Usage PapaMichael6464 Radios 5 May 09, 2014 07:03 PM
For Sale 8 - Used TowerPro MG90 / MG90S Servos: $35 shipped / 8 OR $18 shipped / 4 kelleysislande Aircraft - Electric - Helis (FS/W) 1 Jan 09, 2013 10:16 PM
Sold Price lowered Spektrum DX7 TX NIB + EXTRAS for 4 servo wing fly2bob Aircraft - General - Radio Equipment (FS/W) 5 Jun 15, 2010 06:36 AM
Question Spektrum 4 Servo Wing Setup for Hotliner HotdogX High Performance 6 Apr 27, 2010 07:12 PM
Discussion DX7 setup for my 4 servo wing (electric glider) Vegas_flyer Radios 1 Nov 10, 2007 03:44 PM
