Old Dec 03, 2012, 09:41 AM
98 SNAKE EATER is offline
Find More Posts by 98 SNAKE EATER
Queens, NY and sometimes Orlando, FL
Joined Sep 2003
Motor upgrade suggestions for F550 Hex?
My F550 Hex came with RCTimer 1000kv motors.
I've been more than satisfied with the performance and although I have yet to hit them with the temp gun, they've always been cool to the touch even after hard flying and heavy lifting (multiple GoPro cameras)
Unfortunately, I've had a couple of motors quit in the air due bad solder joints at the bullet connectors
I was able to re-solder them both times, but the wires themselves actually look way too thin and brittle and I believe they're only made up of 3 individual strands
Now, I know there are a million different options out there, but can anyone suggest a solid motor replacement that will give me the same (or better) performance without worry of a wire meltdown?
I'm running 30Amp ESC's and 4S 5000mAh packs exclusively
Since I do tend to pack some extra weight (cameras, landing gear, 3s pack for LED lighting, etc.), I may even consider a heavy lift conversion, but only if I'm able to retain the same ESC's.
Rick <===== currently grounded
98 SNAKE EATER is offline Find More Posts by 98 SNAKE EATER
Old Dec 03, 2012, 07:07 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Tiger MT2216 900kv work well on that frame with either 3s or 4s setups.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 03, 2012, 07:36 PM
okamuwf is offline
Find More Posts by okamuwf
William Okamura
Brazil
Joined Aug 2006
cheap alternative
http://www.hobbyking.com/hobbyking/s...50KV_265W.html
okamuwf is offline Find More Posts by okamuwf
Old Dec 03, 2012, 10:22 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
+1 on the Tigers
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Dec 04, 2012, 05:20 AM
ElectroDie is offline
Find More Posts by ElectroDie
Joined Oct 2012
SunnySky V2216
ElectroDie is offline Find More Posts by ElectroDie
Old Dec 04, 2012, 09:24 AM
blade strike is online now
Find More Posts by blade strike
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Originally Posted by ElectroDie View Post
SunnySky V2216
Yes.. Same as tigers but a lot cheaper
blade strike is online now Find More Posts by blade strike
Site Sponsor
Old Dec 04, 2012, 10:46 AM
Joined Sep 2003
OK, my builder suggested that my motors were probably overworking due to the 1000kv rating and relatively high payload.
He said all of his current builds use lower 750kv units and he has yet to run into issues.
Since he had already sent me one in the past (by mistake), I figured I'd just buy 5 more and give them a shot
So I orded up a new black arm and 5 BL-2830/14 750kv RC Timer motors
I'm still iffy about the wiring, but hopefully it's true what he says about the load.
I guess I can take the leftover motors and build an F450
Old Dec 04, 2012, 10:54 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Those motors are rather large for that size frame in my opinion but will probably work. I use 2814 750kv on much bigger hex.
Edit - I guess that motors sizing is outer dimensions not stator size, so smaller than I first thought so they may be fine.
Site Sponsor
Old Dec 04, 2012, 11:07 AM
Joined Sep 2003
Really?
They actually look tiny in comparison to the stock DJI motors
Old Dec 04, 2012, 11:08 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by 98 SNAKE EATER View Post
Really?
Yes, sorry I assumed that was stator size at first but it is overall size. Various manufacturers use different sizing so it gets confusing. A typical 2830 motor measured by stator would be too big for an F550 frame but those should be ok.
I'd still personally go with the Tiger MT2216s but everyone has different ideas on what is best.
Site Sponsor
Old Dec 04, 2012, 11:10 AM
Joined Jan 2006
You will have to go up on prop size also imho
Site Sponsor
Old Dec 04, 2012, 11:15 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Yes on the 750kv motors you'll no doubt need to go 4S and larger props that you are running now.
What size props were you using on the old motors? 4S on 1000kv would have been a lot so no wonder it was causing issues.
Site Sponsor
Old Dec 14, 2012, 08:35 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
I use 2830/14 750kv in this monster and they work fine
DJI Naza GPS Homebuilt Failsafe (6 min 45 sec)
mikemijal is offline Find More Posts by mikemijal
Old Dec 15, 2012, 12:57 AM
Joined Sep 2003
http://www.youtube.com/watch?v=r2lbf...yer_detailpage
Sweet!!
Are those RCTimer motors though?
Also, would you suggest going with 3-bladed props for an F550?
Old Dec 15, 2012, 05:49 AM
guytzoler is online now
Find More Posts by guytzoler
Israel, Adi
Joined May 2006
How are these?
http://www.rctimer.com/index.php?gOo...4&productname=
guytzoler is online now Find More Posts by guytzoler
Discussion Battery selection for DJI F550 hex kit copters3d Multirotor Talk 16 Mar 30, 2015 07:43 AM
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
Discussion Motor Suggestions for a F550 Clone Guru06 Multirotor Talk 3 Nov 19, 2012 11:03 PM
For Sale DJI F550 Motor Upgrade Kit with Arm Extensions patrick21x Aircraft - Electric - Multirotor (FS/W) 0 Sep 12, 2012 10:56 PM
Discussion DJI F550 motor upgrade: Sunnysky 2216? Jelico Multirotor Talk 1 Mar 11, 2012 06:37 AM
