Old Oct 03, 2012, 05:21 PM
momofx is offline
Find More Posts by momofx
United States, IL
Joined Sep 2012
Help!
Quad 450 wants to keep flipping over! Pics included...
I am pretty new to the quadcopter scene and cant figure out why my 450 wants to keep flipping over backwards! I am using Turnigy x9 with er9x set in simple 4 channel mode. Something I am missing or doing wrong?
Here are some pics so maybe someone can see if my wiring is wrong or something. Thank you.
BTW on the 9x RX : CH1 is Aileron, CH2 is Elevator, CH3 is Throttle, CH4 is Rudder, CH 7&8 are aux...
momofx is offline Find More Posts by momofx
Old Oct 03, 2012, 05:31 PM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Have you calibrated the ESC's to the flight controller?
gitit20 is offline Find More Posts by gitit20
Old Oct 03, 2012, 05:45 PM
momofx is offline
United States, IL
Joined Sep 2012
Honestly, I do not know if I did it right - here is what I did :
1. TX at full throttle and ON
2. Turn on KK2.0 while holding 1st and 4th button
3. Screen says "Calibrating ESCs"
I held it down until it stopped beeping completely. Now I just discovered that somwhere in that calibration process I was suppose to put the stick at zero throttle??? I am not sure where! Blueseries ESCs from HK...
Old Oct 03, 2012, 08:39 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
We def need to flash those ESCs lol
I did it right after the start up beeps. Throttle down.
Then a different beeps sounds. It's complete.
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 03, 2012, 08:41 PM
TheFernMan's Avatar
Joined Jul 2012
What are your PID values?
If you didn't update you KK2 firmware then the default PID values are too high. They were meant for flashed ESCs. Which btw you could do with the BlueSeries you have.
Which ESCs do you have? 30amps?
Old Oct 03, 2012, 09:57 PM
momofx is offline
United States, IL
Joined Sep 2012
Hello,
PI values are as follows ...
Aileron :
P Gain - 50
P Limit - 100
I Gain - 25
I Limit - 20
Elevation :
P Gain - 50
P Limit - 100
I Gain - 25
I Limit - 20
Yaw / Rudder :
P Gain - 50
P Limit - 50
I Gain - 25
I Limit - 10
No I did not update the KK2.0 Firmware which I just got from HK a few weeks ago - is that the latest firmware or do I still need to update it?
ESC is Blueseries 30A
Thanks! Hey also, I forgot to mention I am testing the Quad in a medium sized room - do you think that can have an effect on it and causing it to want to flip right away?
Old Oct 03, 2012, 10:08 PM
TheFernMan's Avatar
Joined Jul 2012
Over at the KK2 thread, some people have mod the 1.2 firmware. Theres one mod that auto level works faster but has one downside to it and someone else made a mod for another thing. I forgot right now.
The boards were coming with original 1.0 which was never made available to public. So once you flash to 1.2 (1.1 was not good. ESC calibration bug) you can't go back.
The update was really meant for people with tricopter and servos. Added a few more things but that was the big point.
Does the menu have a entry for ESC Calibration and entering that menu option show directions? If not, you have newer firmware. Some people had said that their boards are coming flashed already but I'm not certain.
Old Oct 03, 2012, 10:09 PM
TheFernMan's Avatar
Joined Jul 2012
Start with I gain @ 0
The first page of the KK2 thread has a guide for tuning. Follow the guide.
Old Oct 03, 2012, 10:14 PM
TheFernMan's Avatar
Joined Jul 2012
Just read your edit.
Yea you need some room. You cant hover close to the ground. That create prop wash. It's like turbulence.
Some people here will say give it some gas. You need to get it up!
But yea fix that flipping over issue first. ESCs calibration and make sure your motors are turning the right way. The props look on right. Motor one is clockwise with a reversed prop for example.
Maybe make a little video. That help too.
Old Oct 03, 2012, 10:30 PM
momofx is offline
United States, IL
Joined Sep 2012
:o
Yeah the KK2.0 that I have does not have the help screen for the ESC calibration so it must be the latest one I think.
I re-did the ESC calibration and it still tries to flip but after reading your last post I am thinking its because of my room - LOL yeah I feel so silly - it makes sense about the turbulence lol - I will take it out first thing tomorrow and see if it gets up
I will keep you posted tomorrow - thanks alot Fernman. Much apprecciated
Old Oct 03, 2012, 10:38 PM
TheFernMan's Avatar
Joined Jul 2012
Check the motor rotation and Be careful with the props too!
Start think about flashing them. They make a big difference in the performance.
Did you buy the atmel programmer?
Old Oct 03, 2012, 10:43 PM
NYREPZ is offline
Find More Posts by NYREPZ
NYREPZ's Avatar
Joined May 2012
I think you have the motor plugs wrong motor 1 should be top right motor 2 is top left motor 3 is bottom left and 4 is bottom right ,,,try it and see what happens
NYREPZ is offline Find More Posts by NYREPZ
Old Oct 03, 2012, 11:00 PM
TheFernMan's Avatar
Joined Jul 2012
No you're wrong. The KK2 motor lay out is like he has it. M1 is top left and m2 is top right. His picture is fine.
Old Oct 04, 2012, 01:05 AM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
You could try calibrating the esc's one by one instead of through the KK2 board, that's what i ended up doing, apart from that a video would help more.
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Old Oct 04, 2012, 02:06 AM
momofx is offline
United States, IL
Joined Sep 2012
No, I regret not getting the programmer. I will order it soon. Are you talking about flashing the ESCs or the KK2.0 or both lol ?
Hey I think I will try it that way
Once I am sure I got it done right, I will take it out to an isolated part of our local park Hopefully it will not end up in the cornfields nearby I will try to make a video by the weekend hopefully if I dont damage it
Discussion my divinity II keeps flipping need help Wa7sh Foamies (Scratchbuilt) 5 Aug 24, 2012 08:19 PM
For Sale 450 size quad with KK2 and KDA motors etc. Bind and fly! Pics Added! Still for sale! tc3wins Aircraft - Electric - Multirotor (FS/W) 6 Jul 24, 2012 09:12 AM
Help! violent flip over during quad startup Scooter619 Multirotor Talk 12 May 22, 2012 09:06 PM
Help! Quad wants to flip backwards WiseDuck Multirotor Talk 24 Nov 04, 2011 03:17 PM
Help! Quad flips over! quailbird Multirotor Talk 11 Jan 27, 2011 09:34 PM
