Old Sep 28, 2012, 02:11 PM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
New Product
Turnigy TrackStar 1/5 size motor
New motor from HK. Affordable 1/5 size brushless inrunner. Could be a cheap alternative to a CC2028?
http://www.hobbyking.com/hobbyking/s...tor_760KV.html
HobbyKing Daily - Trackstar 1/5 Scale Senorless Motor (1 min 22 sec)
Diesel6401 is online now Find More Posts by Diesel6401
Old Sep 28, 2012, 03:30 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Definately cheaper than a 2028 but unless they're "sand bagging" power figures it's nowhere close in output. Castle "claims" 8000 watts and mine sees over 6000 on a fairly regular basis.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing 90 mm Super Scale F-16
Old Sep 28, 2012, 05:18 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Yea the output number does seen really REALLY low. I've pulled more than that with my CC1717...
Old Sep 28, 2012, 07:15 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
That would need to be run on 10s to do FE boaters any good, they guy says up to 8s for some reason................... Its definately as big as a 2028 in length and diameter.
scorpion1 is offline Find More Posts by scorpion1
Old Sep 29, 2012, 11:00 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
The 2028 is theoretically rated to 8S in a car setup, in a boat it is rated to 10S. Above those, warranty is void.
It's obviously a lower quality motor, but I wonder how much wattage it can actually take?
boaterguy is offline Find More Posts by boaterguy
Old Sep 30, 2012, 07:12 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
It actually makes wattage, you probably know that though
Old Sep 30, 2012, 12:20 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Oh be quiet you
Old Sep 30, 2012, 08:46 PM
Punisher_67 is offline
Find More Posts by Punisher_67
Another Dumb Canadian
Punisher_67's Avatar
Joined Feb 2012
I ordered one of these two days ago and will dissect it when it gets here , as far as being the same size as the 2028 that it is not - close though . The 2028 is 57.0mm x 113.2mm and the Track star is 53.5mm x 114mm or 3.5mm ( 1/8inch ) less in diameter . If there is anyone here that has a 2028 and feels brave enough to take there's apart and measure the rotor size I would really like to compare it to the Trackstar when it arrives . If not no biggie I did take mine apart last year when I had one and I am pretty sure it was about 27mm give or take .
Sandbagging who knows that isn't the first time HK has gotten the specs wrong .
Punisher_67 is offline Find More Posts by Punisher_67
Old Sep 30, 2012, 09:01 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
The 2028's diameter of 57mm includes the fins though.............right?
Old Sep 30, 2012, 10:24 PM
Joined Feb 2012
That is correct but I think this one is also with the fins , there is no doubt that it is still a large powerplant and as you guys figure a little on the underrated side........ For $128.00 it is one hell of a deal
Old Oct 01, 2012, 05:53 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
It could just be a thinner casing. Castle would realize the power of the motor and if one were ever to shed a magnet there would have to be a lot of material there to stop it. a 1/8" vs 1/16" case would make up for the missing size.
Old Oct 01, 2012, 10:20 AM
Joined Feb 2012
If you were to ever shed a magnet it would be the stator that would take the blow not the casing . Any casing that I have ever seen has been no thicker than a 1/16 inch or less . In regards to the Trackstar it is either a smaller rotor and stator or just the stator . Castle's casings are about as thin as everyone else's - if you were to shed a 1/16 you'd have nothing there .
Discussion which size props and motors should I use for 1.5 kg quad? ali26300 Multirotor Electronics 3 Sep 09, 2012 11:10 PM
Sold Nano-Tech 4S 2.2, Turnigy 3S 1.5, Zippy 3S 2.5 Tx, Genesis 2S 4.5 Lipos WiperBlade Aircraft - Electric - Batteries & Chargers (FS/W) 6 Jul 27, 2012 12:46 PM
Discussion KV --and Motor size ? 1/5 Scale EPO 12 lb plane Ldm Electric Motor Design and Construction 6 May 09, 2012 11:28 AM
Sold TURNIGY Sentilon100A HV 5-12S new 80.00 and .60 motor and 120 size motor lazyvida Aircraft - Electric - Power Systems (FS/W) 1 Nov 23, 2011 11:25 AM
Alert [Swarm]Turnigy TrackStar 1/10th Scale 60A Car ESC[Swarm] Dinukap4 Hot Online Deals 0 May 12, 2011 09:34 AM
