Old Jun 02, 2012, 08:55 PM
Griphon is offline
Find More Posts by Griphon
Stangely Spinning in a Circle
Griphon's Avatar
Salisbury, MD
Joined Sep 2002
Question
Right Handed thrower with a left handed vertical?
So I'm putting together a back up DLG since my primary is acting wonky and noticed that the tail set I have for this hybrid are for a left handed thrower. I throw right handed. Since my searching of the groups isn't bearing any fruit, does anyone see a problem with using this vertical? I can still run the pushrod on the correct side, but the hinge is cut on the left side of the vertical.
TIA
Griphon is offline Find More Posts by Griphon
Old Jun 03, 2012, 02:48 AM
glidermang is offline
Find More Posts by glidermang
Griphon:
What sort of vertical is it? Is it asymmetric? Can you turn it over?
Frankly, about the "correct" linkage - I know of two left-handed throwers, who bought right-handed airplanes. They both just put in new blades and forged ahead, without fiddling with the tails at all. They're doing fine (although, admittedly not in contention for World's Champ status).
And finally, I had an airplane with a left-handed tail, no possibility , because of the way it was shaped) of turning it over. I mounted the control horn on the right-hand side, and pressed on (although, admittedly, not contending for the #1 spot myself).
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Jun 03, 2012, 04:34 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
If Im reading this right the only thing that will be different from others is the leverage the control horn has. The thickness of the tail fin to be exact.
You could increase the length of your horn to get the same leverage and then adjust your throws with your radio.
I wouldnt worry about it much unless your a gorilla launcher.
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Jun 03, 2012, 10:06 PM
Shaper Dave is offline
Find More Posts by Shaper Dave
Shaper Dave's Avatar
Oahu Hawaii
Joined Aug 2004
Griphon,
Don't worry about it. Put the horn on the correct side for you and use some rudder offset on the launch mode. You will be good to go.
And start saving your pennies. The Ghost is coming very soon.
Dave
Shaper Dave is offline Find More Posts by Shaper Dave
Old Jun 03, 2012, 10:32 PM
Mr. Shaper Dave!
I'm saving my pennies, too!
Yours, Greg
Old Jun 04, 2012, 05:48 AM
Griphon is offline
Griphon's Avatar
Salisbury, MD
Joined Sep 2002
Originally Posted by Shaper Dave View Post
Griphon,
Dave
Don't tease me good sir. My Arrow 2 is still the best bird in my little fleet and I've been drooling on that ghost since the first pics of the wing.
Question Right hand vs Left hand for DLG lauch? magee8578 Hand Launch 8 Nov 07, 2007 11:17 PM
Discussion Right handers... hand launching with left hand? psycho_klown66 Parkflyers 30 Jul 11, 2007 05:25 PM
Gws Left & Right Hand Pitch Props & Motors For Twins & Multies Demon-Leather GWS (Grand Wing Servo) 0 Apr 06, 2004 10:43 PM
Left and Right hand Props toofastdave Power Systems 4 Jan 11, 2003 09:31 PM
