Old Apr 02, 2012, 03:44 PM
airtimeasto is offline
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Bangalow,Australia
Joined Aug 2008
Question
vaccine bagging infusion
Hi all,
Has anyone already tried resin infusion on a foam bagged wing?
I assume it should work the same.
Asto
airtimeasto is offline Find More Posts by airtimeasto
Old Apr 02, 2012, 04:14 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Infusion typically requires some type of flow media which is removed after cure. With a traditionally bagged wing the flow media would have to be on the outside. You would then have a peel-ply finish on your wing and a bunch of dent's from the flow media.
wyowindworks is offline Find More Posts by wyowindworks
Old Apr 02, 2012, 10:57 PM
There is only DS
Bangalow,Australia
Joined Aug 2008
Definite no go then.
Cheers mate I forgot a out the flow mesh.
Old Apr 03, 2012, 04:45 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Just thinking out aloud... Could you cut at series of spanwise grooves in the core to allow the vacuum ie make the core the flow medium? Obviously, the grooves would have to be narrow and shallow and the mylar / PVC / whatever would need to be stiff enough to bridge said grooves.
As I said, just a thought.
Shedofdread is offline Find More Posts by Shedofdread
Old Apr 03, 2012, 04:50 PM
Just fly it!
Cody, WY
Joined Nov 2007
It is quite possible. That is how sandwich construction is often infused. The grooves are usually visible on the back peel-ply side. The mylar, as you stated, would have to be able bridge these without distortion. It's a good idea.
It would be fun to try....
Old Apr 03, 2012, 07:28 PM
sarmoby is online now
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
Build a mold of the upper and lower wing skins. The mold is joined at the leading edge and open at the trailing edge( looks like a taco). Put dry glass or other reinforcement against the tool, envelope out to the mold then infuse resin from the perimeter.
Once the part cures, remove the bag, unbolt the leading edge and you should have a TACO skin in the airfoil shape. Now, open the taco skin and slide in a foam core with a touch of adhesive. Use a second light bagging until the adhesive sets.
This is how the front wing on formulat 1 cars is often made.
Working backwards....
sarmoby is online now Find More Posts by sarmoby
Discussion Vacuum infusion anthonyd Composites Fabrication 162 Dec 30, 2012 09:47 PM
Discussion Closed-Mold Vacuum Infusion with a Bladder hawaiianspork226 Composites Fabrication 32 Apr 01, 2012 05:04 PM
Sold Custom Sailplane Bag by The Bag Lady Dave Reese Aircraft - Sailplanes (FS/W) 3 Mar 08, 2012 05:44 PM
Discussion HPV Vaccine But No Tanning Bed DT56 Life, The Universe, and Politics 45 Oct 13, 2011 12:52 AM
