Old Feb 09, 2011, 06:49 AM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
Alex,
Congrats on getting the Diawa. I did not realize they made one for our needs. I just bought a Bird with the proper elements on ebay. Got a couple of "N" to sma adapters and am anxious to see the actual output of my 900mhz Tx's.
Have you had a chance to evaluate the Saw filter mod on your 900mhz Rx?
If it would just warm up here maybe I could fly.......
Tom
tom3holer is offline Find More Posts by tom3holer
Old Feb 09, 2011, 01:01 PM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 01, 2012 at 02:50 PM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Feb 09, 2011, 01:06 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
What is that ball made for? I am curious as to what kind of shop to look for it at. I looked at a craft store but didnt see anything like it.
And if the foam doesnt affect it, couldnt it also just be put inside the fuselage, provided the plane is large enough?
Derek_S is offline Find More Posts by Derek_S
Old Feb 09, 2011, 01:28 PM
Joined Dec 2009
Last edited by Mictronics; Jul 01, 2012 at 02:49 PM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Feb 09, 2011, 01:40 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by tom3holer View Post
Alex,
Tom
The SAW mod helped some, but not much. I got better results with a Lawmate RX on the helical antenna than I did with my modded 1.3GHz standard RXs. Unfortunately the Lawmate does not play nice with the skew-planar wheel.
900MHz TX's are VERY sensitive to having the proper antenna. The output begins to drop immediately after the SWR drops below 1.2. I just tested my first ever Vee antenna and found the SWR was about 1.3 or so which dropped the TX output to 400mW. I tested it with my new Vees and got a VSWR of 1.05 and an output of 500mW at 12VDC.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 09, 2011, 02:36 PM
badlands is online now
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Are your newer Vees more dimensionally accurate?
badlands is online now Find More Posts by badlands
Old Feb 09, 2011, 09:47 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
No. Every Vee I have sold is the same. I just tested my first ever Vee antenna which was made long before I started selling them. Every Vee I sold is made for SWR of 1.2 or less.
-Alex
Old Feb 09, 2011, 11:05 PM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
Alex,
Thank you for the comments. I got both the bird and the 400-1000mhz 5 watt element today. I tested the 500mw 900mhz Vtx I had been using in my EZ. It measured, with a bird 50ohm load, 2.6 watts output. I looked at it again and that is what it read. It must be the element or the watt meter. I did buy another 1 watt 400-1000mhz element on ebay. I am off to work for a week so will test it when I get home.
Tom
Old Feb 11, 2011, 06:18 AM
Joined Dec 2009
Old Feb 11, 2011, 06:35 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nice work, Micheal! This confirms my suspicion that the antenna has some polarizaion in the opposite direction. Do you have any of the source files for 4NEC-2?
If I send you the details of my cloverleaf antenna, (which is very similar to the skew-planar wheel but with one less lobe) do you think you could model it? It is basically a 3 lobe skew-planar wheel over a ground plane .2 wavelengths away.
-Alex
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
Originally Posted by Mictronics View Post
So, I worked some math and played with Excel. A quarter of an SPW antenna will be auto calculated now. Copy, paste and rotating can be used in the 4nec2 geometric editor to complete the antenna.
OMM, what you think?
An example, calculated for 1240MHz:
Excellent. I'll give you an A+ if the element lengths and the two key angles are defined as variables inside of 4Nec2. Be sure that the one angle defining the 1/2 wavelength arc can go beyond 90 degrees. With those variables you will be able to do auto optimizations.
Can you show the RHCP vs LHCP plots in 3d Color mode?
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Feb 11, 2011, 06:42 AM
Joined Dec 2009
Old Feb 11, 2011, 06:47 AM
Joined Sep 2007
For now calculation for now is only done in Excel. Phi and Theta angle for the hot Lambda/4 element is variable.
What other plots you want to see? The above show RHCP and LHCP gain.
I would like to see the RHCP and LHCP plots in 3d like this set (from my CPOD antenna):
OMM
Old Feb 11, 2011, 07:02 AM
Joined Dec 2009
Old Feb 11, 2011, 07:05 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Awesome! Excellent work Micheal! Absolutely incredible!
Do you think you could model a 3 lobe skew planar wheel over a ground plane 0.2 wavelengths away? I have been considering this as an RX antenna. It is far easier to build than a quadrafiliar helix.
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
