Old Apr 11, 2015, 07:12 AM
DHarbold is online now
Find More Posts by DHarbold
United States, PA, Lancaster
Joined Jul 2013
After sitting idle on a shelf for close to a year I got my epp fpv out for some fun. I forgot how much weight this thing can carry, crazy!
DHarbold is online now Find More Posts by DHarbold
Old Apr 11, 2015, 03:52 PM
KNote72 is online now
Find More Posts by KNote72
BashMonkeyRC
KNote72's Avatar
United States, OR, Marcola
Joined Sep 2013
What all are you running in it?
KNote72 is online now Find More Posts by KNote72
Old Apr 12, 2015, 06:26 AM
geofrancis is online now
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
i had my video transmitter in the left wing tip and my openlrsng rc/telemetry in the right wing tip to give me maximum separation between them to give me the best range.
geofrancis is online now Find More Posts by geofrancis
Old Apr 13, 2015, 09:02 AM
Joined Jul 2013
NTM 35-48 900KV
Turnigy Plush 60A
Normally run 2 2200 3s in parallel or 3700 3s, either way get 20-30min with my GoPro and fpv gear. I've have yet to have the lipo alarm go off. I plan to install an APM or EZ OSD for some sort of Telemetry/HUD ect
Old Jun 16, 2015, 02:32 AM
Sgt.Flier is offline
Find More Posts by Sgt.Flier
Crashing Instructor
Sgt.Flier's Avatar
United States, LA, Shreveport
Joined Nov 2014
Epp fpv cracked tail boom 9n maiden
Just taxiing around getting courage to take her up and crack right at 6.25", there goes the fun. Anyone else have this happened, fixes or mods?? At least it cracked on ground and not 500 ft up. Going to reinstall with the shorter tail and see how that works.
Sgt.Flier is offline Find More Posts by Sgt.Flier
Old Jun 16, 2015, 11:01 AM
Joined Jul 2013
Ouch!
Old Jun 17, 2015, 03:25 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
A shorter tail will just make the bad yaw stability even worse and also make the elevator less effective. You can employ the method I used to make the tail removable, by using a short piece of 1/2" PVC pipe as a joiner. Depending on the schedule chosen you may have to make a cut in the PVC length wise and then it will clamp right over the tail boom. A couple screws to secure and youre golden
greedyg76 is offline Find More Posts by greedyg76
Old Jun 25, 2015, 07:00 AM
Thorton82 is offline
Find More Posts by Thorton82
Joined Jan 2013
Same thing happened to mine. The propellor cracked the thing during an earlier take off, unknown to me, and the tail ended up falling off during a later take off. I put a smaller piece of carbon rod inside, then filled the gap with poly filler. I then wrapped the broken boom in carbon/kevlar cloth. It is way stronger than the original boom, and the carbon kevlar cloth means prop strikes won't crack the thing now.
Thorton82 is offline Find More Posts by Thorton82
Old Jul 07, 2015, 11:59 AM
LLoo is online now
Find More Posts by LLoo
LLoo's Avatar
Guelph, Ontario Canada
Joined Sep 2004
Hey folks, I purchased this airframe 4 years ago and I never even unboxed it. However I've decided to get off my ass and finally build it. I plan to power it with 2 x 2200mah 3S 35c batteries and will want to carry the following:
- Mobius camera
- FPV camera, vtx
- APM flight controller with GPS, OSD, power module
Scanning this thread I see others fly this plane with a variety of motors and props, does anyone care to comment / recommend their motor and prop setup?
Thanks.
LLoo is online now Find More Posts by LLoo
Last edited by LLoo; Jul 07, 2015 at 12:00 PM. Reason: Reworded question to make it more clear.
Old Aug 02, 2015, 03:16 PM
Joined Jul 2013
I posted mine above, but here it is again. Are you close to getting it in the air?
NTM 35-48 900KV
Turnigy Plush 60A
- Mobius camera
- FPV camera, vtx
Thanks.
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 06:00 PM
