Old Oct 06, 2010, 01:35 PM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
found this tiny circlip ,wheres it go?
found this tiny circlip near my landing area today .looked down and seen it gleeming,just a lucky find actually.
wonder where it goes?i have a cb100.
does it go on the steering rod?
its tiny.i put it in some tape so i wouldnt lose it .theres a speck of crumb next to it for size reference .its tiny.
any ideas?i havent a clue
By null at 2010-10-06
helizrnew2me is offline Find More Posts by helizrnew2me
Old Oct 06, 2010, 01:59 PM
micronut is offline
Find More Posts by micronut
dont play with rc anymore
micronut's Avatar
United States, MO, St Joseph
Joined Feb 2005
You might try asking in the micro heli forum. It goes on a shaft, somewhere.
Could be main shaft, tail shaft, motor shaft, etc.
micronut is offline Find More Posts by micronut
Old Oct 06, 2010, 02:05 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Looking at this diagram the only ones I see are inside the blade grip
http://www.helipal.com/images/Helipal-CB100-diagram.jpg
1320fastback is offline Find More Posts by 1320fastback
Old Oct 06, 2010, 02:13 PM
Joined Sep 2010
wow ,that blew up nice .thanks alot .i,ll check that out .
so cb100 is considered a micro?
Old Oct 06, 2010, 02:38 PM
Joined Sep 2010
well you were right ,they are both missing from the grip .i proceeded to install this one when it went "ping".now its gone forever.
where i am gonna get this part now??these things are so tiny ..i need a bigger heli...lol
Old Oct 06, 2010, 03:30 PM
n00b-E is offline
Find More Posts by n00b-E
Tread Elsewhere
n00b-E's Avatar
United States, CO
Joined Sep 2007
Yes, you do. Try this!
n00b-E is offline Find More Posts by n00b-E
Old Oct 06, 2010, 03:35 PM
Joined Sep 2010
i,d like a 450 ..but not a kit .blue ray looks nice ..or the e-razor 450
Old Oct 06, 2010, 04:20 PM
n00b-E is offline
Tread Elsewhere
n00b-E's Avatar
United States, CO
Joined Sep 2007
Well, I guess its a kit by traditional definition, but I found it to be more of an ARF, with only major components needing final assembly. I admit it's not as easy as a RTF heli what with having to make the final adjustments and all, but I've never had an RTF that I didn't have to adjust to get the darned thing to fly correctly!
I can't comment on the models you listed as I have no experience with them, but I will say that bigger definitely flies better. I'm going up to a 500 after the first of the year.
Old Oct 06, 2010, 04:32 PM
Dusty1000 is offline
Find More Posts by Dusty1000
Scotland the Brave
Dusty1000's Avatar
United Kingdom, Scotland, Glasgow
Joined Mar 2008
The 4#3B has exactly the same circlips. They always used to ping off, and we used washers which were found inside the old brushed motors instead. I'm not sure what folk are using nowadays, but I'll bet someone has found something that fits - I would check the CB100 threads in the micro-heli forum.
Dusty
Dusty1000 is offline Find More Posts by Dusty1000
Old Oct 06, 2010, 04:41 PM
jombo is offline
Find More Posts by jombo
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
not sure how small that is but home depot sells e-clips, also check harbor freight , i know they sell them by the box assortment
jombo is offline Find More Posts by jombo
Old Oct 06, 2010, 05:15 PM
Pontiaddict is offline
Find More Posts by Pontiaddict
Pontiac my other Obsession
Pontiaddict's Avatar
USA, FL, Apopka
Joined Jul 2010
yes i would be willing to bet HD, actually Lowes if you have one nearby has a better choice in that type of hardware.
Pontiaddict is offline Find More Posts by Pontiaddict
Old Oct 06, 2010, 07:42 PM
Joined Sep 2010
i stopped at hobbytown usa and bought the smallest ones they had in a assortment pack ,and they werent small enough...lol
the washer is a good idea ,i see these flying off alot as i only have about a dozen or so flights in .
did you double stack the washers?just use enough to fill the void?
the heads a little sloppy without the circlips .
Discussion broken Rx antenna wheres it go Masterofbizaster Electric Motor Design and Construction 3 Jun 28, 2010 09:05 PM
Discussion broken Rx antenna wheres it go Masterofbizaster DIY Electronics 2 Jun 28, 2010 08:55 AM
Help! found this old clock and im wondering if i can use the parts to make a tiny actuator PinoyRC Electric Motor Design and Construction 2 Dec 23, 2007 03:36 AM
Discussion Tiny EDFs... how tiny do they go? Rusty-Gunn Foamy EDFs 3 Oct 09, 2006 06:16 AM
Brushless Tiny on Troy's new 450 Kokams- GO baby GO!!! Tres Wright Parkflyers 101 Feb 10, 2003 06:36 PM
