Old Sep 13, 2008, 12:32 PM
" DID U SEE THAT!!!? "
davonat's Avatar
Oconomowoc Wi
Joined Mar 2008
Question
F3B wiring
Howdy guys........
My brand new Millenium will be here in a few days . I bought the F3B build clinic. Is it really nessesary to wire the wing servos direct to the switch? I will be installing a Spektrum 6200 reciever, and a 6 volt battery. If I were to buy a Hoopes harness....Does it direct the wing servo power wires to the switch? My soldering skills arent the best. Thanx Davo
davonat is offline Find More Posts by davonat
Old Sep 13, 2008, 04:33 PM
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Wiring Harness
Hi,
you may want to try one of these...
http://www.soaringusa.com/products/p...ategory_id=269
Happy Landings!
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Old Sep 13, 2008, 04:37 PM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
what switch? is there some special thing you have to do with spektrum. I would just wire up the loom like normal. i.e the servos get the power via the RX. unless i am missing something.
satinet is online now Find More Posts by satinet
Old Sep 13, 2008, 07:24 PM
davonat's Avatar
Oconomowoc Wi
Joined Mar 2008
Video says........
The video recommends you wire the wing servos directly off the battery and only connect the signal wire to the receiver. That way you bypass running your wing servo power thru the receiver. It doesnt matter the Brand of rec. they were using a JR I believe. Davo
Old Sep 13, 2008, 07:35 PM
Paul Naton's Avatar
Lewisburg, PA
Joined Apr 2002
The direct wire scheme I show in the DVD is a nice simple way to save on wire and power the digital servos direct from the battery.
You can run most set ups off of the receiver if you wish, thru a switch.
Either way works.
Paul Naton
F3 Building Clinic
http://radiocarbonart.com/Pages/F3main.html
Paul Naton is online now Find More Posts by Paul Naton
Site Sponsor
