Old Jul 23, 2014, 02:50 AM
Joined Jan 2014
from octocopter to dodecacopter prop rotation
Hi guys,
I recently built an octocopter from Hubsan h107 spare parts. It's working great! But now I want to kick it up a notch. I want it to have 12 props/motors instead of 8. Now I was using the left illustration from the image below because I need an X config because the flightcontroller is build for X. Is there anyone here who can tell me what rotation I should use for 12 motors in an X config?
Here you can see the current one with 8 motors/props:
H107 Hack Octocopter - Normal-Mode (2 min 26 sec)
and here:
H107 Hack Octocopter - Pro-Mode (1 min 16 sec)
hannemaster is offline Find More Posts by hannemaster
Old Jul 23, 2014, 09:36 PM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hmmm. You might get someone here who can answer your question, but the folks who hang out in the Multirotor section here:
http://www.rcgroups.com/aircraft-ele...ltirotors-790/
are probably your best bet. Good luck, that's one heckuva chopper...
Steve
Steve85 is online now Find More Posts by Steve85
Old Yesterday, 02:52 AM
Joined Jan 2014
Steve
Thanks, will try to get an answer there!
Discussion Correct rotation for counter rotating dual props? 98 SNAKE EATER Scale Boats 14 Oct 16, 2013 06:29 PM
Question Do big props with lower kv need any more thrust angling (to counter rotation torque) RC Aerobat Electric Plane Talk 4 Oct 03, 2013 02:10 AM
Discussion Problem with 10x4.5 counter-rotating props from Todd's Models?? Windriver Multirotor Talk 9 Jun 12, 2010 10:16 AM
Discussion Counter Rotating Motors/Props from Himax glue_sniffer Scale Kit/Scratch Built 10 Jun 12, 2007 07:21 PM
Discussion New reverse rotation props from APC soon? Work in Progress Scale Kit/Scratch Built 0 Oct 19, 2006 11:27 AM
