Old Sep 06, 2013, 04:00 PM
Joined Feb 2004
Thanks Ward
My lathe is an old Myford with no auto feed just a nice Bernerd chuck. I have a big single phase Chinese mill/drill with a round stock with plenty of tooling (just need a decent adjustable angle plate). Most of this has been done with hacksaw and files:-).
Wetafly is offline Find More Posts by Wetafly
Old Sep 07, 2013, 02:36 AM
Joined Jul 2013
In the UK the x and y axis are the Horizontail axis and the Z is the vertical axis and as far as I am aware this is the excepted convention, I was a little confused at first as to what you were refering to with regards to axis orintation but now understand.
Mick Gannon is offline Find More Posts by Mick Gannon
Old Sep 07, 2013, 09:31 AM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
It is confusing....I think that the convention in naming an axis is that Z is in line with the cutting tool, which is in this case the wire.
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Sep 07, 2013, 09:17 PM
Joined Feb 2004
Left XY and Right XY is how GMFC is set up which is what I have been using for years. I am not sure about other programmes. I have started to think about other programmes but will stay with GMFC as long as Gilles keeps supporting it.
Old Sep 08, 2013, 04:19 PM
Joined Feb 2004
Nothing really new here just progress on the second Y axis.
Old Sep 08, 2013, 09:24 PM
Joined Feb 2004
Started on the bearing mounts for the X axis threaded rods. I decided to have bearings at both ends because the motor coupler is not true or very supportive.
Old Sep 09, 2013, 05:05 AM
Joined Feb 2004
Machined the ends of the threaded rods. In spite of the threads they true up fine in the 4 jaw chuck:-)
Old Sep 09, 2013, 08:10 AM
San Diego
Joined Mar 2003
Nice.
You going to use a bow or spring setup for tensioning the wire?
Old Sep 09, 2013, 03:26 PM
Joined Feb 2004
Hi Ward I use bows of different lengths as I move the towers a fair bit depending on the panel size. I will make all new bows for this machine as I have a plan for integrating them better.
Old Sep 09, 2013, 08:48 PM
Joined Feb 2004
Got the first X axis done. I expect some fine tuning will need to be done once I get the motors turning but it seems to be nice and smooth at the moment. I've nearly used up a 200 piece jar of 4mm CS screws and 100 5mm bolts.
Old Sep 10, 2013, 12:18 PM
Canada
Joined Nov 2000
Wow! complex and careful work.
Seems like the Hobby is building machines not merely melting up Foam construction insulation
Bare is offline Find More Posts by Bare
Old Sep 10, 2013, 10:02 PM
Joined Feb 2004
I love the wide range of skills this obsession requires. Design, woodwork, metalwork, composites, electronics, flying skill and probably a few more.
Got the second XY done today. Now for the bow mount and the wiring.
Old Sep 11, 2013, 08:57 PM
Joined Feb 2004
Made the bow holders today. One end will remain relatively fixed and the other end will slide to allow for thermal expansion and panel taper. Measured thermal expansion of my longest bow, 1670mm wire .25mm inconel. It was 6.5mm.
Old Sep 12, 2013, 06:59 PM
Joined Feb 2004
Got the bow stay on. I need to find some 5-6mm stainless rod for the bow legs which will slide in the slot.
Old Sep 14, 2013, 11:01 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
When you get done I would be willing to do all the testing for you. Of course to do a proper testing job may take "several" years. At the completion of the testing period, I will submit a complete report on the operation and any improvements that will make it a better machine.
Ken
PS a typical report goes something like this.... It worked great.
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: FAA & Model avaition
Discussion CNC Foam cutter Tension jcyr1 CAD/CAM 22 Jan 16, 2014 06:25 AM
Help! cnc foam wing cutter build HELP! mlggeek CAD/CAM 20 Aug 16, 2013 06:25 PM
Discussion starting to build my own cnc/foam cutter azzou CAD/CAM 0 Jun 24, 2013 06:55 AM
Discussion CNC Foam Cutter for Hire? tyates5445 CAD/CAM 5 Apr 24, 2013 05:04 PM
Discussion home made cnc foam cutter DEBAY777 Foamies (Scratchbuilt) 5 Feb 01, 2013 06:06 AM
