Old May 22, 2013, 06:53 PM
Forever Remain...
United States, NV, Las Vegas
Joined May 2013
Question
Wasp X3V & Hi tec Servo's?
My question, I have a FBL Wasp X3V, that I bought here in vegas, I have had a few crashes, and all that ever gets broke, are those VTS-05B servo's. problem is I cant get them at the stores here, unless I bribe the clerks to let me switch out my broken VTS-05B's with working ones on return's other custumers have brought in. I bought 3 Hitec HS-55's which seem like better servos, but I get this bizzare issue, so I cant use them, but would like to know what the issue is cuased by.
The Issue is, when I put all 3 HS-55's in, or even 1, lets say on the elevator, the servo is reversed of course, forward cyclic equals backward, so reverseing on the NASA701 XMITR fixes that of course, but thats not the issue, the issue is whether the channels are reversed or not, when the left stic is pressed up for throttle/pitch up, it goes down, even when the channels are reversed, so I am assuming that the HITEC servo's are incompatible with the wasp and or skyartec, is this true? and why?
Thank you very much.
phoeboskrieg is offline Find More Posts by phoeboskrieg
Old May 24, 2013, 11:29 PM
United States, MI, Auburn Hills
Joined Dec 2008
Asked and Answered
We explained much of this in direct emails, trying to offer support on a product we did not sell, in an attempt to compensate for the lack of support this customer has experienced from his dealer - simple answer is that the 3 axis gyro is setup to work with servos of a very specific timing, rate and reponse time - additionally to use 3rd party servos that have the opposite throw from normal, like Hitec, you must change the direction in the X30x receiver unit using the programmer
As the system works as advertised with the OEM (Skyartec) servos; the buyer must then decide if they want to use 3rd party servos and also determine on a case by case basis rather they want to take on the changes to the setup that the other servos might need.
Max
www.parkrcmodels.com
www.skyartec-usa.com
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old May 26, 2013, 09:08 PM
Canada, ON, Ottawa
Joined Jun 2009
Your servos are swinging the opposite way. Servo rotates according the pulse width of the signal applied to it. A wider pulse causes one type of servo to rotate clockwise and another type to rotate anticlockwise. Just like we have right hand screws and left hand screws.
Don't change the setttings on the TX. Change the reversal settings on the RX (X302V/X303V) using an USB cable. Changing the TX settings will not fix the reversal for gyros inside the RX. Changing on the RX can fix both if done correctly.
If you are familiar with electronics and soldering, you may reverse the wiring to the motor and pot inside the HS-55 servo to make it swing the same way as the stock servos. That would work too.
Wasp09 is online now Find More Posts by Wasp09
Old May 27, 2013, 01:04 AM
Joined Dec 2008
3rd Party Servos
WASP09 is correct - with the X302 you will need to reverse the wiring on the Hitec Servos or upgrade to the X303v receiver unit so that you can use the programmer to change the direction of the servos in the receiver firmware -
Max
Site Sponsor
For Sale HEAVY DUTY SERVO ARM SET FOR HI-TEC HS-85 HS-5085 hs-225 5245 24 TOOTH 3drcparts Aircraft - General - Radio Equipment (FS/W) 0 May 07, 2013 06:06 PM
Sold HI-TEC..RCD 3200 Rx's(4) Hi-Band...$35.00/ SHIPPED.. Pigeon 49 Aircraft - General - Radio Equipment (FS/W) 0 Apr 19, 2013 01:00 PM
For Sale Servo lot traxxas and hi tec. bclong211 Aircraft - General - Radio Equipment (FS/W) 0 Apr 08, 2013 08:14 PM
Sold Hi-Tec 625MG servos BrianSmith Aircraft - General - Radio Equipment (FS/W) 3 Mar 19, 2013 02:43 PM
Discussion WTS: Hi-Tec Servos shredderbond Singapore 0 Mar 14, 2013 12:58 PM
