Old Feb 22, 2013, 09:59 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Can I make wood putty?
I know the flour and CA trick, But this big dent is in the leading edge of a finished wing, CA would probably get where I don't want it.(doesn't it always?)..... is there a paintable alternative?
Thank you in advance!
scootrb4 is offline Find More Posts by scootrb4
Old Feb 22, 2013, 10:22 AM
Jacksonville Fla.
Joined Mar 2007
Why not use light weight spakle compound
jetmech05 is online now Find More Posts by jetmech05
Old Feb 22, 2013, 11:40 AM
Illegitimi non carborundum
grosbeak's Avatar
Joined Mar 2011
I've had great success with Model Lite filler.
grosbeak is offline Find More Posts by grosbeak
Old Feb 22, 2013, 11:45 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I agree with the spackle if its just a surface dent.( i use it all the time myself ) I'm sure you have heard of the water & heat method to raise the wood as another way to remove a slight dent.Another way,if its too deep,is that you may have to cut into the wood and replace it with new wood & then sand it to the desired shape. When i was a kid i made putty with balsa dust & elmers white glue. It was difficult to sand since it was harder than the surrounding wood, but worked in a pinch.....Gene
gene6029 is offline Find More Posts by gene6029
Old Feb 22, 2013, 12:46 PM
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
It depends on the area you're planning to fill, how thick the filler will be (if it's really thick, use balsa as a filler), and what your filling will be covered with. I've used spackling (regular and light weight), Elmer's wood filler, epoxy and micro-balloons, and balsa sawdust/sanding dust or talcum powder mixed with carpenters glue. I've stayed away from anything mixed with CA since the CA cures very hard and makes it difficult to sand (I have seen dirt mixed with CA for a field repair).
Hogflyer
hogflyer is offline Find More Posts by hogflyer
Old Feb 22, 2013, 06:48 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
this is what I use for all non structual filler!
if it's structural, I use epoxy and dalsa sandings!
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: heli's
Old Feb 22, 2013, 08:11 PM
scootrb4's Avatar
Joined Nov 2011
Whiskey, where I'm gonna fine dat dalsa sand? LOL
Thank you, Gene. I'm old enough where I'm forgetting some of the tricks I used to know...crap.
This ding is on the leading edge and you could hide a pencil in it. I thought of lightweight Spackle right away, but I'm worried it will not be durable enough for every day (flight) handling. Thanks agin
Old Feb 22, 2013, 08:37 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
scootr if its that big, you might hafta think about fitting in a chunk of balsa, and shaping ta match!
Old Feb 27, 2013, 09:50 PM
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
If its that big... just cut a chunk of balsa wood down and glue it in.. sand it... throw some lightweigt spackle in there.. and just final sand it.
If wood was in the ding before.. wood would (punn intended)..be best to put back in there. Me thinks so... but thats just me.
DGrant is online now Find More Posts by DGrant
Old Feb 28, 2013, 03:51 AM
GaryHarris's Avatar
Joined Jun 2011
Patch-n-paint.
GaryHarris is offline Find More Posts by GaryHarris
Old Mar 03, 2013, 09:44 AM
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
If it's the shape of a pencil too how about cutting a piece of dowl and epoxy that in place? Then mix some sawdust and epoxy to fill the small gaps left. I would have to take a piece of balsa and a sanding drum to make the dust though. I don't build from kits( or at least haven't yet) so I don't have any dust on hand.
V2rider is online now Find More Posts by V2rider
Old Mar 04, 2013, 10:39 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
The "Old Man" here -just passing through...I use lightweight spackle on minor dings, too big to swell back to shape..Fill it and sand it to final finish, then flood it with thin C/A.
You won't 'ding' it there again.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: Back to square one !
Old Mar 04, 2013, 07:27 PM
scootrb4's Avatar
Joined Nov 2011
The simplest things are genius at times. I know the old baking soda and CA trick but it gets so hard you can't shape it afterwards....... your idea to shape the lt wt Spackle (which I deemed too soft) and then flood it with CA is genius to me. Yet obvious! I like it. Thank you. I shall try that on a sample to see how it goes.
Question Can I make my motor wires 30"-40" Long? jonathan7x70 Power Systems 11 Jan 29, 2013 04:25 AM
Discussion Does someone here makes (or can point someone who can) custom Composite Airframes? Reginak UAV - Unmanned Aerial Vehicles 7 Jan 21, 2013 06:29 AM
Discussion Does someone here makes or can point someone who can, custom Composite Airframes? Reginak Composites Fabrication 4 Jan 15, 2013 06:00 AM
Discussion You can't make up stuff this good. seanpcola Life, The Universe, and Politics 45 Jan 06, 2013 03:02 PM
Discussion Fixing Foam. Is there a putty I can use? IL2windhawk Foamies (Kits) 6 May 21, 2009 08:16 AM
