Old Feb 19, 2013, 09:22 PM
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Invest in some of this stuff.
http://www.rcgroups.com/forums/showthread.php?t=1827097
herrmill is offline Find More Posts by herrmill
Old Feb 22, 2013, 02:58 PM
United Kingdom, England, Exeter
Joined Feb 2012
Is there any type of foam I should use. just regular stuff or special shaping foam?
dan_d_diver is offline Find More Posts by dan_d_diver
Old Feb 22, 2013, 03:36 PM
can you land on that ?
Scottish Highlands
Joined Jan 2005
Sheffield Insulations ( there is a branch near you, check Yellow Pages ) The standard blue foam used in the construction and building trade is the stuff you want. It absorbs less than 1% moisture. Easy to work, cuts with saw, hot wire and sands well. Won`t resist polyester unless with a barrier but OK with epoxy. Comes in various thicknesses in 8x4ft sheets (or metric equivalent). Oh yes, try to get some Corrosion-X for dipping your radio and electronic gear, from USA.
arrow5 is offline Find More Posts by arrow5
Old Feb 22, 2013, 04:46 PM
Bloomington, IL
Joined Apr 2004
You basically want closed cell foam. Most DIY stores will have some variant. Such as the pink "Foamular", or the blue foam. I believe these types are called extruded polystyrene foams.
Open cell foam will gradually get waterlogged. I would avoid the white bead foam that can also be found in hardware stores.
eRaptor is offline Find More Posts by eRaptor
Old Mar 05, 2013, 10:42 AM
Michio's Avatar
Leiden,Netherlands,Europe
Joined May 2010
Last summer I did some fpv-boating, just for fun. I made an airboat/swampboat because I had the parts for it. I'll share my experience..
The waves are difficult to compensate, the boat tilts in all directions, including up and down. Place the camera's in the center to minimize that. Wind and currents make the boat drift, causing rotation. When sailing the motor makes noise, could be a problem for wildlife approach. (airboat sounds like airplane, bad choice)
The low point of view causes the water to mirror/reflect. Think about backlight compensation when choosing the spot to shoot from, the sun also reflects on the water and hull (paint it black!). All this considered, the idea of a barge as platform seems logical.
Pointing the camera would need a video signal transmitted to the operator...
Quick compulation of the footage from the airboat, forgot to mute sound...
Hope it's helpfull...
Airboatcompulation (2 min 15 sec)
Michio is offline Find More Posts by Michio
Help! New to RC Boats; Needs Advice for Drive Line old_dude Dock Talk 7 Aug 25, 2008 02:39 PM
Discussion Advice for a Novice Picking His First Gas Powered RC Boat mkockler Racing Boats - Internal Combustion 2 Jun 10, 2007 07:37 PM
New Product RC Hot Air Balloon Camera Platform for sale... hergibear Aerial Photography 1 Aug 26, 2006 03:11 PM
Help! r/c boat camera platform zane mathias Dock Talk 4 Feb 21, 2006 11:07 AM
