Old Jan 16, 2013, 01:10 AM
Joined Jun 2012
Motor heating up to 80+ deg C during no load tests
This is a 174 gram motor (http://www.hobbyking.com/hobbyking/s...ner_Motor.html) doing a no load current test on 4s, my OSD reads 2.8 amps, could be innacurate (will check with wattmeter later), and after about 3-5 minutes of this, it gets to 80 degrees C (measured with temp probe).
That seems like it shouldn't happen unless it is either going through massive winding resistance (which I find unlikely, will test tonight as well) or something like the ESC motor brake being partially on and dumping energy straight into the motor.
The ESC is a 60a plush from several years ago.
Can anyone tell me what could be going on?
Nereth is offline Find More Posts by Nereth
Old Jan 16, 2013, 04:40 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
There's nothing wrong with the motor or ESC. The problem is the 3-5 minutes of running with no cooling.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jan 16, 2013, 04:41 AM
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Thats why you should newer run a motor no load for more then a few seconds, its the iron losses that heats up the motor, and at 80C you`ll risking to demagging the magnets.
MagnusEl is offline Find More Posts by MagnusEl
Old Jan 16, 2013, 07:21 AM
Joined Jun 2012
What causes the iron losses? I.e. what are they proportional to? Current? Rotational speed? Voltage? Load? Switching speed?
Because it seems like a fair amount of heat generation to have to deal with in the air - the cooling on that motor is pretty bad even though I have cut huge holes in the foam around it to promote airflow, almost no air is able to run through the core of the motor, only some hits its left and right sides while it runs.
Old Jan 16, 2013, 08:12 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.aveox.com/DC.aspx
http://www.rcgroups.com/forums/showthread.php?t=1630005
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 16, 2013, 08:40 AM
Joined Jun 2012
Thanks Dr Kiwi!
So looking at that thread, most of them are saying that, in the same motor, it is chiefly proportional to RPM, or values that change in lockstep with RPM (commutations), although someone mentioned current (not sure whether to conclude current matters or not...).
If that is the case, and current doesn't matter, then indeed these losses will not increase, and may infact decrease, when a prop is added and max speed decreases slightly? Not to mention potentially added cooling.
Old Jan 16, 2013, 09:13 AM
Dr Kiwi's Avatar
Joined May 2003
However the heat is generated, imagine turning on a 40W bulb for 3-5 minutes, then holding the glass globe in your bare fingers!
Old Jan 16, 2013, 09:17 AM
Joined Jun 2012
I assumed, before this thread, that most of that current was used splashing air around inside and around the motor, so I didn't think the heat was dissipated internally =D
Old Jan 16, 2013, 09:58 AM
Chicago 'burbs
Joined May 2006
Originally Posted by Nereth View Post
Thanks Dr Kiwi!
The current does matter! The heating is coming from the power supplied by the battery--under no-load, it is basically being turned into heat. In this case it is going into the magnetic heating, both hysteresis and eddy current losses, and perhaps some minor bearing. There is a little resistive heating too, I suspect not much.
Just mutlply that current by the voltage to give you the wattage.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Jan 16, 2013, 10:23 AM
Joined Jun 2012
I don't know specifically what each one (eddy and hysteresis) is since it's been years since the few minor electrical courses I did, but would I be right in saying one (eddy?) is the currents induced in the laminations by the magnets of the motor moving around them, and the other (hysteresis?) is the magnetism induced and reversed in the same plates as the current in the wires reverses, and the heat generated from this inefficient process?
The losses from the former would be independent of current, the losses in the second would be linearly related to it as far as I can reason, as long as the waveform in the windings is the same? Is one of them negligible compared to the other?
Old Jan 17, 2013, 05:52 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
No load losses are mainly
a) Magnetic hysteresis losses
b) Eddy current losses
c) friction losses (BB + noise)
d) ESC losses (probably small, not easy to estimate)
e) copper no load losses are very small generally
An order 3 polynomial W versus rpm is generally a good fit
see graph for 3 Dualsky XM6360 different windings
http://www.rcgroups.com/forums/showp...77&postcount=2
Heat is developped both in the stator lams and in the rotor
Louis
Fourdan is offline Find More Posts by Fourdan
Discussion No Load Bench Test, Watts, Amps mybad Power Systems 6 Jan 03, 2013 07:15 PM
Discussion 65 deg C motor temp Ab74 Multirotor Talk 1 Dec 05, 2012 01:58 AM
Discussion Can a motor heat up if lectroglide Electric Motor Design and Construction 2 Jun 17, 2012 08:10 PM
Discussion How hot should a motor get during static test? Slaphappysamy FPV Talk 1 Jun 06, 2012 06:20 PM
Help! Saito 1.80 Load up Cls044 Engines 12 Apr 24, 2012 07:37 PM
