Old Oct 16, 2012, 04:16 PM
Joined Sep 2012
Question
A newby's question about Hinge Tape
Hi Guys,
I have two newby questions about hinge tape please:
1) How does it differ from ordinary tape, and
2) What is it's purpose.
I know that people put it on the hinges of control surfaces (such as ailerons), but I'm not sure why. Is it to decrease turbulence over the joint, or hold the parts together if the hinges break, etc? I'm also unsure how it's different to ordinary tape.
Thanks in Advance
adza is offline Find More Posts by adza
Old Oct 16, 2012, 04:44 PM
United States, NM, Las Cruces
Joined Jul 2012
It is used to reinforce the joint and will even hold the hinge together if the foam hinge (or other actual plastic hinge breaks). It tends to be a little stronger and clearer than regular tape. I use regular tape (3M clear gift tape I think it is called) because it is cheaper and seems to work just as well for I what I use it for. I just put it on the underside of the hinge, so you can't see it anyways.
erikc641 is offline Find More Posts by erikc641
Old Oct 16, 2012, 06:40 PM
USA, IL, Wheaton
Joined Oct 2010
For Park Flyers, the tape can replace the hinges and hold the surfaces in place. It also seals the hinge line to stop air flow through it that makes control action less efficient. Lots of flexible tapes can be used, with package sealing tape one favorite. I've had best luck with a medical tape from 3M called "Blenderm", which DuBro repackages as Park Flyer Hinging Tape.
DuPageJoe is offline Find More Posts by DuPageJoe
Old Oct 16, 2012, 06:47 PM
Oldgzr's Avatar
Finger Lakes Region, NY
Joined May 2008
post deleted.
Oldgzr is offline Find More Posts by Oldgzr
Last edited by Oldgzr; Oct 16, 2012 at 06:51 PM. Reason: DuPageJoe answered the question
Old Oct 16, 2012, 10:06 PM
Joined Sep 2012
Thanks for the info guys!
Old Oct 17, 2012, 02:47 AM
United States, MI, Monroe
Joined Jun 2009
The blenderm is really good hinge tape, soft and flexible, but really durable with good adhesion, still holding up after a few years on my first T -28. Really would not want to use anything stiffer.
Tony K is offline Find More Posts by Tony K
Old Oct 18, 2012, 10:59 AM
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
I agree. I use it on the tail of my T28 since it has those weak hinges from factory. It seems to work very well. Like was said above you use it for hinges to replace or reinforce them on foam type planes. The packing tape works great for reinforcing other things like wing edges, bellies,etc... I have never used it for hinges though.
JoshB is offline Find More Posts by JoshB
Old Oct 18, 2012, 03:43 PM
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Regular packing tape will last at least 7 years - might last longer but I don't know yet.
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 18, 2012, 03:52 PM
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
FWIW, no matter the tape used, I go over the hing tape with a covering iron turned up just enough so it softens the glue in the tape, and then use it to push the tape into the foam. I've had some pretty impressive crashes where the taped hing holds up just fine. And as it's a foamie, so does the plane
And some tapes are better than others... As some have mentioned Blenderm is great, but I picked up package of 2 large rolls for $4.00 of Walgreen's brand "Blenderm" and it works as well. I also found genuine 3M office tape to be far superior to the generic variates.
rcav8r2 is online now Find More Posts by rcav8r2
Old Oct 19, 2012, 11:22 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
I have 2 areas of concern with tape :
a) Introduce paint into the equation and most tapes lift ... and fail. Whether you apply before painting or the worst is after !
b) I never had problem with this years ago when folding back a surface, apply tape, fold surface other way and apply tape other side .. now it seems as soon as I do that .. the surface opens up a gap that is too sloppy.
I prefer proper hinges or mylar strip ... tape to seal the hinge line and provide back-up .. and of course as another says - repair when foam hinge gives out.
Nigel
solentlife is offline Find More Posts by solentlife
Old Oct 20, 2012, 09:03 AM
buyer of the farm
United States, FL, DeLand
Joined Mar 2009
Also, keep in mind that brand name matters, but 3M has a dozen specialized varieties of medical tape, some of them with names suspiciously close to Blenderm. On the advice of my wife, who assured me that it would be the same I used one of them on my Slow Stick. It was awful. The gummy adhesive just crawled all over my elevator and horizontal stabilizer, gumming everything up while allowing the tape to move wherever it wanted. I had to remove, degum and replace with workable tape!
Rockin Robbins is online now Find More Posts by Rockin Robbins
Old Oct 20, 2012, 03:56 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
For the very light indoor foamies I use Micropore, made by 3M and bought at a medical supply store. More of a paper type lightweight material. Been using for a few yrs with no problems. Takes paint well being of paper type.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Discussion newby question about flying upwind black6088 Beginner Training Area (Aircraft-Electric) 16 Jul 02, 2012 03:55 AM
Discussion Newbie , question about my first quadricopter dxtr Multirotor Talk 2 Jun 08, 2012 01:31 PM
Discussion Questions about Kevlar hinges ,LE ,and transfer tape TahoeDirk Hand Launch 20 Apr 02, 2011 08:15 PM
Discussion More questions on hinge tape - tape over film covering? Mike-O Sailplane Talk 7 Sep 01, 2010 11:09 PM
Question about hinge tape cruzomatic Electric Plane Talk 14 Jan 08, 2002 09:45 PM
