Old Sep 12, 2012, 09:57 PM
Joined Jun 2004
Soaring Sim Question
Hi Everone
I am like to know what sim offer some of the current F3b / F3j gliders? I am looking for the Freesyler , Supra, Explorer, multi channel type of glider for slope as well as flat land flying.
Also some scale types.
mack5 is offline Find More Posts by mack5
Old Sep 12, 2012, 10:18 PM
FS One
MSelig's Avatar
United States, IL, Champaign
Joined Sep 2005
FS One
Originally Posted by mack5 View Post
Hi Everone
FS One has the Supra and the scale Swift aerobatic glider (and some others). It also has all kinds of wind setups for thermal, DS and slope + 3D turbulence. It also has hi-start and winch launch + hand launch. Also, you can do aero towing.
MSelig is offline Find More Posts by MSelig
Old Sep 18, 2012, 05:10 AM
Mr Rowl's Avatar
United Kingdom, England, Oxford
Joined Jul 2002
Hi Everone
I've been working on a simulator that's mainly focussed on gliders - see here for the (free) Android version.
I'm just finishing the iOS version, and then will sort out a Windows version, which has the obvious advantage of being able to use a transmitter/joystick/gamepad.
It has slope and flat-land flying, with thermals, 3D turbulence, wind flow including separation (i.e. rotors and DS), ground/follow views, panoramic and 3D sceneries etc and a pretty wide range of gliders (including Weasel, Phase 6, Le Fish, Discus, Genie plus lots more including two non-gliders). It's very configurable, and on Windows at least you can (will be able to) pretty easily set up your own scenes/planes (also on Android, but it's more fiddly!).
Any feedback on it would be very welcome!
PicaSim - Flight simulator for radio controlled aircraft (5 min 30 sec)
Catching thermals with the Genie in PicaSim (3 min 34 sec)
Mr Rowl is offline Find More Posts by Mr Rowl
Old Sep 21, 2012, 01:57 PM
Cromer,Norfolk, UK
Joined Nov 2006
Looking good, is this an "update" of the SSS simulator? which I still have, complete with the ropey old Corsair PSS model and a couple of others I made for it, I was quite touched by them being included
Any idea of a release date for the windows version?
Matt
MCarlton is offline Find More Posts by MCarlton
Old Sep 21, 2012, 02:09 PM
Mr Rowl's Avatar
Joined Jul 2002
Essentially yes, except it's a complete rewrite, apart from one or two bits. It's based on the same ideas, but with improvements to the aerodynamics, physics and wind modelling. Also the configuration system is usable by non-programmers now!
I'm using a library called Marmalde to help make it portable between different platforms. At the moment I'm using the cheapest licence which just covers iOS and Android. When the time comes to renew at the end of this year I'm planning on upgrading to the (more expensive) version that covers a Windows release. It might happen earlier, depending on how things go on iOS.
Old Sep 28, 2012, 06:16 PM
United States, CA, Bakersfield
Joined Jan 2001
Hi Everone
Phoenix 4 has the Nan Models Shadow and the Parkzone Radian as well as some un-named sailplanes. I haven't tried it so I don't know how good it is at simulating soaring.
georgeg is online now Find More Posts by georgeg
Old Oct 01, 2012, 10:32 PM
FS One
MSelig's Avatar
Joined Sep 2005
Hi Everone
Here's the Supra doing some thermal soaring in FS One V2. The launch is with a hi-start.
FS One V2. Supra high-performance sailplane. (1 min 54 sec)
Discussion Free slope soaring sim... av8ersteve Electric Sailplanes 2 Sep 07, 2012 08:25 PM
Help! Sim question CottonMouth Simulators 4 Jul 09, 2012 09:02 AM
Question Best sim for slope soaring josh18 Simulators 6 Jun 07, 2012 12:02 PM
Discussion Realflight Sim question Alex Schauer Electric Plane Talk 25 Mar 09, 2012 03:04 PM
Discussion question about real flight sim ? genzod Electric Plane Talk 5 Mar 05, 2012 02:49 AM
