Old Apr 23, 2012, 03:30 PM
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
eflite 100 degree electric rotating retracts
I own a set of these. They are very nice and reliable.
However, the struts are a little soft. With 4 mm they are just not quite up to the task I think. I'd like to replace them with something stronger.
Anyone here that has upgraded the struts with something stronger?
Anyone here that has removed the struts from the trunions?
I am wondering how the trunions are constructed (the struts are removable, but there is rotational tension on them, so I am not sure what happens if you pull them out of the trunions, i.e. if you can simple remove and replace them.
Regards Dave
struggleforlife is online now Find More Posts by struggleforlife
Old Jun 26, 2014, 09:36 AM
Joined Jul 2004
Old thread, but would also like the answer to this!
soaringtuna is offline Find More Posts by soaringtuna
Wanted 100 degree rotating retracts Top flite corsair 60 arf wheels down Aircraft - General - Miscellaneous (FS/W) 1 Dec 20, 2011 09:28 PM
Question 10-15 Size ROTATING electric retracts? stevehookem Flight Accessories 6 Dec 16, 2011 06:19 PM
Wanted Rotating Electric Retracts Blue Falcon Aircraft - General - Miscellaneous (FS/W) 0 Oct 21, 2011 06:25 AM
Sold E-Flite 100 Degree Rotating Retracts curtusua Aircraft - Electric - Airplanes (FS/W) 1 Oct 19, 2011 12:33 PM
Wanted Broken Eflite 60-120 electric retracts. mikes68charger Aircraft - General - Miscellaneous (FS/W) 1 Sep 13, 2011 09:10 AM
