Old Jan 21, 2012, 08:33 AM
Peppern75
peppern75's Avatar
Norway, Buskerud, R°yken
Joined Aug 2005
Clyde Puffer
For many years I've been thinking about building a scale boat. One day I came over a drawing and some pictures of a Clyde Puffer.
Then I've started drawing on my PC. The results are shown here.
peppern75 is offline Find More Posts by peppern75
Old Jan 21, 2012, 08:50 AM
Peppern75
peppern75's Avatar
Joined Aug 2005
Some parts must be cut out of plywood, 12 mm for the keel and 4 mm for the other parts
Old Jan 21, 2012, 09:34 AM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Puffers are neat. Nice use of the computer to generate your frames. Will yours be steam powered? I imagine you could fit a small oscillator motor in the hull, but I'm not sure about the fitting of a boiler in the scale position, unless it was a small one. Regner has a small boiler+engine combo unit.
Brooks is offline Find More Posts by Brooks
Old Jan 21, 2012, 11:41 AM
Peppern75
peppern75's Avatar
Joined Aug 2005
The scale of my Puffer will be 1:12, the hull will be 170 cm long and 46 cm wide. This will mean a weight about 50-60 kg. I don't know if there is a steam engine that is big enough to use in this model. If it exist, it is wery expensive. I am going to use a geared electric motor and a couple of small car batteries (40-50 Ah). The propeller is a 3-blade 130 mm.
Some gluing has been done .....
Old Jan 21, 2012, 12:55 PM
Brooks's Avatar
Joined Aug 2003
I certainly misjudged the size of your boat, hoho :-). You'd have no problem with fitting steam engines and boilers*smiles*. Steam motors would be plenty powerful enough. My friend has a 4 foot steam tramp that runs on the cheapest oscillator available in the US, namely the Midwest Heritage package (about $120 boiler + motor). His hull is narrower than yours, so would move more easily thru the water than your Puffer.
But there are other motors, eg. the Graham 2 cylinder TVR1A, which would move your Puffer fine (about $250, fully machined, just assemble with handtools). The boiler is the most expensive part, unfortunately. Maccsteam 3 1/2" would do the job, but costs about $550 plus shipping.
The Midwest Heritage is the cheapest way to get into the steam side of the hobby (short of scratch building motor and boiler). But, your Puffer hull type and size are probably more than the oscillator could handle. Maybe build a steam launch for your Puffer? *smiles*
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSM83
http://www.grahamind.com/tvr1a.html
http://www.maccsteam.com/Horizontal_...e_boilers.html
Some Maccsteam boiler and Graham engine tests I ran:
http://www.rcgroups.com/forums/showthread.php?t=1216529
Old Jan 21, 2012, 01:14 PM
Peppern75
peppern75's Avatar
Joined Aug 2005
This was interesting. Maybe some more expensive than an elektric motor but something to think about.
In Norway it is saturday evening now, and some more parts have been cut out from plywood, then taped together to see how it fits.
Old Jan 21, 2012, 01:25 PM
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Peppern, good choice for a model boat. Puffers have lots of gritty character---.
der kapitan is offline Find More Posts by der kapitan
Old Jan 21, 2012, 01:29 PM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
Very nice start !
Tim B. is offline Find More Posts by Tim B.
Old Jan 21, 2012, 01:38 PM
Joined Jun 2005
Tim, have you noticed how neat and tidy these European modelers are---?
Old Jan 26, 2012, 02:33 PM
Peppern75
peppern75's Avatar
Joined Aug 2005
Testing some paint, and drawing with a marker to imitate planks, before using colored stain.
Old Jan 26, 2012, 03:20 PM
CurtisP40's Avatar
Joined Oct 2011
Holy crap. This is a big model. What dimensions?
CurtisP40 is offline Find More Posts by CurtisP40
Old Jan 26, 2012, 03:49 PM
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
It's the perfect size .
Mark
the goon is offline Find More Posts by the goon
Old Jan 26, 2012, 11:19 PM
Peppern75
peppern75's Avatar
Joined Aug 2005
Yes, that's right, It's the perfect size. The scale is 1:12 and it will be 170 cm long, 46 cm wide and total height 136 cm. The weight must be approx. 60 kg.
This will be a low cost boat, because I mainly build model airplanes, but I will try to make some details.
You can look at my model airplanes here: http://smartweb.no/pernil/
Old Jan 27, 2012, 11:23 AM
Joined Jun 2005
Big---, about 5'-8" long---.
Peppern must be a pretty strong fellow if he's going to heft that model to the water---.
Old Jan 27, 2012, 11:29 AM
can you land on that ?
Scottish Highlands
Joined Jan 2005
Big enough to sit IN , ifn he`s of slight build !
arrow5 is offline Find More Posts by arrow5
Discussion Clyde Puffer Stu Kerrn Micro and Sub-Micro Boats 22 Apr 04, 2011 04:04 PM
Discussion hull planking for 1/20 Clyde Puffer sdav834 Scale Boats 8 Jan 21, 2009 08:07 AM
Discussion Anyone built a Caldercraft Clyde Puffer? TugFan Scale Boats 3 Nov 30, 2008 02:16 PM
CalderCraft Clyde Puffer hotjava Scale Boats 4 Nov 29, 2005 03:14 PM
