Old Jul 26, 2012, 05:45 PM
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Originally Posted by Busher View Post
I have a few questions regarding the ZYX field programmer.
Can you upgrade to the latest software for the field programmer and still use it to adjust an older version 2.5 zyx. ?
Or do you need 2 programmers one for the older versions and one for the newer ZYX - s version.
I updated my programmer with latest firmware from Tarot and then used it with my ZYX v2.5 without any problem. I have not tried to use it with ZYX-S v3.x yet.
Ching-Ho Cheng
lcc014 is offline Find More Posts by lcc014
Old Jul 26, 2012, 08:59 PM
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Hi Guys, just finished my 4th ZYX heli . So thats a Thunder Tiger MT 450, Tarot 450 pro, Tarot 450 sport with TT and the Tarot 500
barnstorm100 is offline Find More Posts by barnstorm100
Old Jul 26, 2012, 09:02 PM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I bet a 600 is next.
fpainter3 is offline Find More Posts by fpainter3
Old Jul 26, 2012, 09:14 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
You must be able to set them up in your sleep, now.
beenflying is offline Find More Posts by beenflying
Old Jul 27, 2012, 12:12 AM
Turkmenistan, Ahal, Ashgabat
Joined Jul 2006
Originally Posted by chewytm View Post
Hi,
How do you get it into airplane mode? I don't see anything in the program to set it up in airplane mode. I have just been playing around with the program and have not tried to do any serious setup yet.
chewy
I use ZYX-S and software version 3.0. There is a page (in the middle of the setup steps) for airplane mode.
PB
PB3D is offline Find More Posts by PB3D
Old Jul 27, 2012, 12:18 AM
Joined Jul 2006
Originally Posted by Dr.M View Post
That sounds like too much gain on ailerons. Try decreasing the Roll total gain a bit and test fly.
This is my setup:
Roll P gain =10
Roll I gain =10
Roll D gain=0
Which roll should be reduced?
Thanks very much.
PB
Old Jul 27, 2012, 12:32 AM
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Originally Posted by PB3D View Post
This is my setup:
Roll P gain =10
Roll I gain =10
Roll D gain=0
Thanks very much.
PB
I'd go for the total gain on the main page.
Dr.M is offline Find More Posts by Dr.M
Old Jul 27, 2012, 06:26 AM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I would try to add little D. It is sometimes defined as a subtraction of gain as the Process variable rapidly approaches the set point.This can stop an oscillation before it begins.
Old Jul 27, 2012, 06:31 AM
Joined Sep 2005
ZYX firmware upgrade to version 3.50.rar(only use in ZYX)
http://www.kingwjg.com/zyx/zyx%203.50.rar
ZYX-S firmware upgrade to version 3.50.rar(only use in ZYX-S)
http://www.kingwjg.com/zyx/zyx-s%203.50.rar
1.Optimize the heading hold control, eliminate bouncing when spin brake.
2.Optimize the main rotor control, eliminate swing while tic toc.
3.Accelerate the response speed of joystick, so that the helicopter can follow your hands better.
4.Optimize the pirouette compensation to make pirouette flight more stable.
5.Improve the joystick dead band setting to make stick control smoother.
First Flight Attention with 3.50 Version:
1.During first flight, if there are hunting or swing with you helicopter, please decrease the D gain on corresponding axis first.
2.When tail servo is on neutral point, set the tail pitch to be approximately 8°in the direction that compensates the main rotor torque by adjusting the linkage length.
3.If the brake speed of left and right pirouette are different, please adjust the "Deceleration L" or "Deceleration R". The higher parameter value, the break will be faster.
Firmware upgrade instruction
1.Connect the ZYX gyro to PC by ZYX USB adapter,click "Connect ZYX",make sure it succeed.
2.Open the Firmware in ZYX PC software.
3.Keep the PC,USB adapter and ZYX gyro connecting.Power off ZYX gyro,press "SET" button of gyro and power on.
4.The red lamp is flashing,click "Upgrade" button to start upgrade,the ZYX gyro will restart after successful upgrade.
5.Please make sure your gyro is Tarot ZYX,otherwise the gyro will be damaged.The ZYX gyro does not need to be setup again.
http://www.0577mx.com/news_view.asp?clsid=15&id=268
Tarot ZYX Gyro on gasser
康覺之假日在河堤飛T700G影片 (4 min 46 sec)
unochen is offline Find More Posts by unochen
Old Jul 27, 2012, 06:42 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Excellent!!! I've been hoping there would be an update soon. Thanks unochen.
Old Jul 27, 2012, 07:17 AM
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
http://youtu.be/UT5DdTi_gXo
yes! thank you!!! I knew being patient on my 250 Tarot ZYX build pays off!! This is exactly what I've been waiting for!! Oh and that is some superb piloting skills unochen good job!
pitchp is offline Find More Posts by pitchp
Old Jul 27, 2012, 07:27 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Thanks, I can now upgrade ZYX to 3.5 !!!
Ching-Ho Cheng
Old Jul 27, 2012, 10:18 AM
mhills51's Avatar
kansas city
Joined Feb 2007
Just down loaded
mhills51 is online now Find More Posts by mhills51
Old Jul 27, 2012, 10:39 AM
wlee1017's Avatar
Joined Jul 2011
great. I just download 3.5, can't wait to perform firmware upgrade on 250 and test flight.
wlee1017 is offline Find More Posts by wlee1017
Old Jul 27, 2012, 11:13 AM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
WOW! Thank you so much. Now, I may buy another one for my 600-size heli which is in the build process.
ricoalonso is offline Find More Posts by ricoalonso
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
