Old Mar 08, 2011, 05:01 AM
Joined Mar 2010
Question
Premier Vector unit Gen 1
Hi
Please can someone tell me what diameter carbon tube was used on the Premier vector thrust unit 1st Generation to construct the frame ?.
And what the weight of the entire power unit is excluding the battery ?
My scratch unit seems a little heavy or so i think.
Maxflight is offline Find More Posts by Maxflight
Old Mar 08, 2011, 05:19 AM
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
Here is the PremierRC manual:
http://www.premierrc.com/pdf/VectorUnit_Manual.pdf
realglow is offline Find More Posts by realglow
Old Mar 08, 2011, 05:28 AM
Joined Mar 2010
i have the manual but it doesn't seem to give the weight or anything about the tube diameter.
Thanks Anyway
Old Mar 08, 2011, 05:33 AM
Joined Mar 2010
Clone VT unit
Here are a couple of cellphone pics of my scratch vector unit
Old Mar 08, 2011, 05:57 AM
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
What did you use for the gimbal ring? Looks very professional.
BTW: You may want to consider adding servo saver springs to each of your pushrods; even with a prop saver, a prop strike can strip the gears on a servo. Metal gears help also. Don't ask me how I know!
Old Mar 08, 2011, 06:08 AM
Joined Mar 2010
Gimbal Ring
You wont believe it.... its a chromed plastic curtain ring , its about 3 grams and 55mm or about 2 inch diameter and as hard as hell.
I almost went to an engineer to have some aluminium rings made.
Old Mar 08, 2011, 06:32 AM
United Kingdom, England, Bognor Regis
Joined Feb 2011
Originally Posted by Maxflight View Post
Hi
A Premier Gen I frame without battery weight is 250 grams (approx)
(I have a Turnigy switch fitted and a bit a extra wiring for LED lights on the Canard)
Frame is made from 5.5mm Exel RCF carbon
Very nice unit you have made, is that a Premier motor? and what method did you use for joining the carbon ?
Dave
Mitchy123 is offline Find More Posts by Mitchy123
Old Mar 08, 2011, 10:43 AM
Joined Mar 2010
Dave
Thanks for the info Dave
My VT unit is constructed from 6mm cf tube and weighs 189 grams. I'm pretty happy with that.
The frame is tacked with ca , I then used about 10 strands of polyester sewing cotton and wrapped the joint .give it a quick burn with a cigarette lighter to get rid of the fuzz, the soak joint with ca.
The motor is a 24 gram hextronic motor 1300 kv it will pull about 700 grams.
Thanks again Dave
Old Mar 31, 2011, 08:21 PM
USA, TN, Collierville
Joined Jun 2010
I've been trying to find these rings, please tell me where you found it.
Geoff
glsmith1544 is offline Find More Posts by glsmith1544
Old Apr 01, 2011, 04:56 AM
Joined Mar 2010
Geoff
Sorry Geoff i'm in South Africa
This worked for me in Google "chrome drapery rings Collierville"
Regards
Max
Old Apr 01, 2011, 09:05 AM
Joined Jun 2010
Thanks, guess I should have considered you're location!
I appreciate your reply.
Geoff
Old Apr 01, 2011, 11:25 PM
California
Joined Feb 2011
Geoff
Geoff. Check this and see if you can use it. Try a 2" black plastic pipe coupler made for plumbing pipe. I looked at them in Home Depot the other day. You will need to cut it.
nocg is offline Find More Posts by nocg
Old Apr 02, 2011, 01:54 PM
Joined Jun 2010
Thanks nocg, I have begun to make one as you suggest only using a white PVC fitting.
In fact, I'm anxious to get it far enough along to take pix & share with everyone! I'm feeling like it will be a good one, but lest anyone thinks I'm getting "cocky", it will be obvious that the majority of my ideas came from all of you plus some other websites including S.P.A.D.
Old Apr 02, 2011, 10:53 PM
California
Joined Feb 2011
A pipe coupler is a pipe coupler. The only difference is the color. I will be interested in seeing and reading about your progress.
Old Apr 20, 2011, 03:57 PM
Joined Jun 2010
Been a while but I'm happy to tell you, per your suggestion, I checked out the black fittings. Turns out they are ABS while the white is PVC. The ABS seems a little lighter & I found one I think will be ideal for my purposes. So, THANKS for the suggestion! So far about all I've done is "thinking" about my project, will update when I actually accomplish something LOL!
Discussion Premier RC Vector Kites Patron RC Kites 22 Oct 24, 2011 12:15 PM
Gallery First thrust vector unit balsa or carbon RC Kites 7 Feb 22, 2011 06:13 PM
Discussion Scratchbuilding a vector unit TheNiceGuy RC Kites 12 Feb 22, 2011 01:31 PM
New Product R/C Vector kites by Premier Designs STRINGFLY Parkflyers 16 Feb 01, 2011 07:47 AM
Wanted Vector unit JIMFRISKY Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2011 04:10 PM
