Joined Jul 2011
Turnigy 9x v2 & stk500v2 (SFAR Multitool)
I come back with a topic I've tried to solve a while back. So, to start:
================================================== =============================== Started AVRDUDE E:/Program Files (x86)/eePe/avrdude.exe -c stk500v2 -p m64 -B 100 -v -P com2 -U eeprom:r:C:/Users/Sandman/AppData/Local/Temp/temp.hex:i ================================================== =============================== avrdude.exe: Version 5.10, compiled on Jan 19 2010 at 10:45:23 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "E:\Program Files (x86)\eePe\avrdude.conf" Using Port : com2 Using Programmer : stk500v2 Setting bit clk period : 100.0 AVR Part : ATMEGA64 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 4 20 64 0 no 2048 8 0 9000 9000 0xff 0xff flash 33 6 128 0 yes 65536 256 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : STK500V2 Description : Atmel STK500 Version 2.x firmware Programmer Model: STK500 Hardware Version: 2 Firmware Version Master : 2.10 Topcard : Unknown Vtarget : 4.9 V SCK period : 82.5 us Varef : 0.0 V Oscillator : Off avrdude.exe: stk500v2_command(): command failed avrdude.exe: stk500v2_command(): unknown status 0xc9 avrdude.exe: stk500v2_program_enable(): cannot get connection status avrdude.exe: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude.exe done. Thank you. ================================================== =============================== AVRDUDE done - exit code 1 ================================================== =============================== And this is what I keep getting. I have a windows 7 x64, everything else is as per topic. I've soldered (about 3 times already) a connector to the board. The connections are correct and working (checked for impendance from each atmega pin to the connector pin). I've tried:
So far, I've been unable to pinpoint the problem. I'm starting a separate thread, because the conversation around here died. If You've got any ideas, please share them. Thanks! |
| Thread Tools | |
| Discussion Benefits of buying FlySky TH9x (v2) over Turnigy 9x (v2) | wwfisher | Radios | 29 | Apr 25, 2013 11:00 AM |
| Discussion Turnigy 9x v2 mode 2 trouble with throttle and rudder | Huginn81 | Beginner Training Area (Aircraft-Electric) | 1 | Mar 24, 2012 09:19 AM |
| Sold Turnigy 9X V2 transmitter w backlight mod, Corona 2.4 module and 4 Corona receivers | jgpncll | Aircraft - General - Radio Equipment (FS/W) | 3 | Mar 20, 2012 07:01 AM |
| Sold New Turnigy 9x v2 board ER9x installed | TyCarp | Aircraft - General - Radio Equipment (FS/W) | 2 | Feb 28, 2012 08:42 AM |
| Wanted Turnigy 9x receivers v2 (8ch) | simplefly | Aircraft - General - Radio Equipment (FS/W) | 2 | Feb 26, 2012 04:27 PM |
