Old Nov 24, 2006, 06:26 AM
Joined Sep 2006
Help!!!!!!!!!!!!!!!!!!!! Giant Corsair
This model is a 86 " wingspan, I have loaded the nose with about as much weight as I can and it is close to balancing, but not there yet. Any ideas????????????
Brian
Brian Coleman is offline Find More Posts by Brian Coleman
Old Nov 24, 2006, 09:16 AM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Add more weight or fly it tail heavy. What else can we say?
Viper Pilot is offline Find More Posts by Viper Pilot
Old Nov 28, 2006, 12:27 PM
Joined Sep 2006
BC,
What engine is in her? You may need to get a heavier engine or lighten the tail end by removing some wood here and there. Get the nose weight as far forward as possible. Make sure the battery pack is up to the firewall and fastend down good. I trust you are balancing your F4U with the gear up, right? I also must ask if you are balancing this bird inverted. You may also get a heavier prop hub. Good luck.
Later,
TopKick
TopKick is offline Find More Posts by TopKick
Old Dec 26, 2006, 03:31 AM
Joined Nov 2006
I,ve seen weigth added to a half motor mount along side the engine in attempt to move it out futher from fire wall. Don,t weigth the cowl or you will have problems!
wylieruneyjr is offline Find More Posts by wylieruneyjr
Old Jan 10, 2007, 07:39 PM
United States, IL, Naperville
Joined Sep 2005
How much are you off by? What engine, battery location right now? etc.
rheumatical is offline Find More Posts by rheumatical
Old Jan 13, 2007, 09:07 PM
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Brian
Brian, what is the all-up weight as it stands now? Whatever the weight the balance needs to be correct (and with the gear UP!) or you will have a very short lived Corsair. I assume you already know that if you are flying big scale warbirds. I flew a Byron Corsair (85" span or so) with a G-62 and over 6 pounds of lead up front. All up weight was around 31-32 pounds ready to fly and it flew just fine. It did need to be respected around the stall but the airplane was a delight to fly.
Chad Veich is offline Find More Posts by Chad Veich
Need Help to ID Corsair DrBill Sport Planes 0 May 22, 2004 10:48 PM
Could use some help finding a corsair voyantus Foamies (Kits) 5 Feb 12, 2004 01:03 PM
Motocalc help for Corsair, please. silly stick GWS (Grand Wing Servo) 2 Dec 20, 2003 11:58 PM
need help with corsair retracts 67bigdog Parkflyers 15 Dec 02, 2003 10:03 PM
Need Help with corsair 67bigdog Parkflyers 2 Sep 27, 2003 07:04 PM
