Old Sep 24, 2014, 07:20 PM
Joined Sep 2014
Help!
60inch Rc FiberGlass Boat Motor?
Ok so i have a 60inch boat that weighs a lot and im running a 8s battery but can't seem to find the right motor to get the boat up to 45+ mph so i need some help please!
boatboy900 is offline Find More Posts by boatboy900
Old Sep 24, 2014, 09:27 PM
Joined Oct 2011
What motor are you running now?
What ESC?
Prop?
Hull Type?
Battery brand and C rating and Capacity???
Details are your friend.
dobydog6507 is offline Find More Posts by dobydog6507
Old Sep 25, 2014, 04:05 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I assume its a Vee hull......................
If so and 45 mph is your goal, a Leopard 56110 should get you there, although 8s is a bit low voltage-wise. 10s with the 640kv and a largish prop would be good for that boat in that speed range. If you are set on 8s the 780kv would be best since you will need a good sized prop to move that honker. Best overall, but pricey choice, would be the Castle 2028.
scorpion1 is online now Find More Posts by scorpion1
Old Sep 26, 2014, 06:09 AM
Joined Oct 2007
Hello,
For that size of boat , think 10, 12S, not less. for motor, weight is not really a problem, a 700gtrs motor is enough, but 1 kg is acceptable. For batteries, you should think of mulricopter batteries, like Gens aces 16000, two 6s packs in serie can give you 45Mph for 15 minutes.
People here are racers, they will often recommends you, big motors, High C rate batteries, small props, but if you prefer long runtimes, efficiency, 45-50Mph range. You will find my advice good.
brushman is online now Find More Posts by brushman
Old Sep 26, 2014, 01:44 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Originally Posted by brushman View Post
Hello,
C'mon man. You can't recommend a motor by weight. That doesn't tell him anything.
What size & KV would YOU use on 10s or 12s & what size prop to go with it to give the45mph for 15minutes?
785boats is offline Find More Posts by 785boats
Old Sep 27, 2014, 02:19 AM
Joined Oct 2007
hello,
first , I need to know the empty weight of the hull without any hardware, if it is less than 4 kg, you can expect a 11 kg boat equiped. I am using HET-RC 800-73 / 400 Kv on a 50" hull with 12S 16000 and a K70 prop. This setup gives me 23 minutes runtime at 40 Mph. If you put a 76mm prop or a X472, it will do 45 Mph on a 60" boat for 15 minutes.
Enjoy:
E-Fighter by Brushman. (4 min 51 sec)
This hull is a 60" mono and can be used in electric: http://www.toys-port.hu/en/mono_sync_cross.html
I have to say that i do not put batteries for recption, no radio box, and always lo king for weight saving. This is my way of building boats, Lightest batteries, motor, esc, hardware . low CoG, big size prop.
Old Sep 27, 2014, 10:26 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I'm assuming the motor is this ducted fan unit? Since it is a smallish motor i like your idea of 400kv on12s, only way to wring "boat power" out of it really, however i dont recommend this small of a motor to the OP.
Product Information:
-Diameter : 50 mm
-Length : 72.7 mm
-Shaft Dia. : 8 mm
-Weight : 495 grams
-Internal resistance: 12.8
-No load current (lo): 1.9
-Max efficiency: 88%
-Poles : 8
Old Sep 27, 2014, 11:12 AM
Joined Oct 2007
yes and no, a good motor for turbine will have large bearings, a lot of vents, and is able to pump 100A continusly, this motor compares to the 1900ZR sold by Andrew Gilchrist a few years ago, Andrew has a good knowledge in motors,.
Poles number is very important also, for the same weight/Kv, a higher pole count will be more effcient.
My mono will use a Xnova outrunner 4030/350 , to increase the run time, I wiil use a K76 prop or Octura X472. Motor weight is 440 grs.
Scorpion 1, I understand why you are using "big" motors, because you have to keep the boat on water at high speed and for cornering, you have to do less than 10 laps, but many of us are not racing, or we have to race for 5 minutes, and big motors will not help.
Old Sep 27, 2014, 05:32 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
So which is it? post 6 says it is the HET
hello,
And post 8 says it's Xnova out runner.
bill34207 is offline Find More Posts by bill34207
Old Sep 28, 2014, 03:17 AM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Everything is conjecture until "boatboy900" bothers to answer dobydogs' questions in post #2.
We might even be dealing with a Cat, or a Hydro. Who knows?
C'mon Boatboy. Where are you?
Old Sep 28, 2014, 04:06 AM
Joined Oct 2007
Yes,
purely conjecture!
Actually, it is the HET in this Ocean spray MHZ, but I will replace it with the Xnova, the average amp draw will be 35A, easy for my powerjazz 120...
Old Sep 28, 2014, 09:38 AM
Joined Oct 2011
He hasn't been on here since he posted his original question....
For Sale 35" RC R/c EP Epoxy Fiberglass Twin Power Catamaran Cat Racing Boat Ship Kit wjdid Boats (FS/W) 5 Sep 14, 2014 05:07 AM
Sold *Sold* Genesis Electric Brushless RC Fiberglass Boat with water cooled motor and ESC. jbj620 Boats (FS/W) 0 Jul 20, 2012 10:39 AM
For Sale Fiberglass F1 Brushless Motor Electric RC Speed Boat ARTR wjdid Boats (FS/W) 0 Mar 16, 2012 09:57 PM
For Sale Fiberglass F1 Brushless Motor Electric RC Speed Boat ARTR t161 Boats (FS/W) 8 Sep 18, 2011 02:57 AM
Wanted RC Motor Yacht Style Fiberglass Electric Boat ShokWaveRider Boats (FS/W) 2 Mar 07, 2010 11:43 AM
