Old Aug 22, 2014, 02:28 PM
United States, ME, South Portland
Joined Jun 2014
scaling up and down plan
Hi all
i don't think you can just enlarge or make smaller the planes to a plan. So what do need do to up scale or down scale to keep all the # working and or stay in scale ( if you want)
grumbling_dwarf is offline Find More Posts by grumbling_dwarf
Old Aug 22, 2014, 02:41 PM
Staffs, UK
Joined Nov 2003
Why can't you just enlarge or reduce a plan ? It's worked for me several times. Of course you may need to adjust wood sizes etc. if you go far from the original.
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 22, 2014, 05:22 PM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Depends on how much you scale it. If you double the size you may also need to do things like increase the number of ribs and formers, or change some of the structure to make it stronger, like landing gear and the LG mounts.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Aug 24, 2014, 03:14 AM
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
Photoshop works best for me. Every plan I get I have scanned to get a tif file of the plan.
From this point on I can scale it, in Photoshop, symmetrically or just in the vertical or horizontal plane. I can also flatten it, stretch it, compress it, or fatten it, to what ever I want.
After Scaling a plan down the first thing I look at is the rib spacing seems to me that standard rib spacing is between 2.5 and 2.75 inches on .25 to .60 sized plans. So I adjust the spacing accordingly subtracting a rib or 2 when scaling down or adding a rib or 2 if scaling up.
Fuse formers seem to scale so that you don't need to subtract when scaling down or add when scaling up.
Edit----
Here's an example of how to scale ribs up or down. You can also use the same method to scale the rest of an existing paper plan.
Roguedog is offline Find More Posts by Roguedog
Last edited by Roguedog; Aug 24, 2014 at 04:13 AM. Reason: Added a rib scaling article
Old Aug 24, 2014, 09:50 AM
David
dmarusa's Avatar
United States, TX, Houston
Joined Mar 2012
Roguedog, this is excellent. I will be using this today. I have scalled up a ff design with tapered wings 200% and need to add a rib to each bay. I have always plotted a second set of ribs and drawn a line around the perimeter half the difference between it and the next smaller rib outline. It has never been perfect, but close enough. I'll give this method a try.
dmarusa is offline Find More Posts by dmarusa
Old Aug 24, 2014, 10:19 AM
builderdude's Avatar
United States, TX
Joined Jun 2011
I simply take the plans I want to enlarge, to a good print shop and have them enlarge it.
Yes, you have to deal with some issues, but they're not hard to deal with.
Take for example, that 1/8" runners will appear 1/4" thick if you enlarge it 200%.
That doesn't mean you HAVE to use 1/4" runners. You can still use your 1/8" and just compensate on your building table. I've done it many times.
Charlie's right about # of ribs. Sometimes, you end up with ribs that are just too far apart. When I enlarged my Vampire to 38" wingspan from the original Jetex plans that were about half that size, my wing ribs were so far apart that I ended up doubling the number of ribs.
So you compensate on the fly, where you have to, to make the enlarged plan work.
But also keep in mind that enlarging might also mean you need to introduce a couple of improvements, such as a ply dihedral brace for the wing instead of just balsa.
Overall, it's not that hard. And going to a print shop is not that complicated either.
builderdude is offline Find More Posts by builderdude
Old Sep 12, 2014, 06:32 PM
United States, FL, Chuluota
Joined Jul 2013
I just resized a set of plans at Staples. They have a large priner that scans your plan then they put in the percentage, mine happened to be down sizing and then it printed the new size. But this took two trips as the first person scanned it into their computer then resized it and when it printed it was the wrong size plus she hit size to the page which through it off shape. The second person did it just with the printer and it turned out perfect.
Bob
bobmrbassman is offline Find More Posts by bobmrbassman
Old Sep 13, 2014, 08:23 AM
The Junk Man
Jacksonville, Florida
Joined Jul 2006
After literally decades of manually altering plans for the size wanted, I started using CAD to do the job and have never been happier. I was lucky enough to get to try Solidworks for 7 or 8 months (before my son's company wanted the laptop and seat back ) and Rhino before it was sold as part of a startup graphic business I owned. Both were outstanding. And Rhino is even pretty affordable as these things go. Solidworks is not... many thousands of dollars.
But I came back to SketchUp. Free, several bazillion free tutorials on the web, and a huge userbase that produces many plugins to greatly increase the usability of the program.
It is perfectly capable of doing everything a modeler needs to do.
Then, scaling plans you have done yourself or traced into the program becomes a two-click operation.
Tom
T_om is online now Find More Posts by T_om
Old Sep 13, 2014, 09:31 AM
Joined Jul 2013
Tom
Thanks Tom, I might try that
Bob
Old Sep 15, 2014, 06:05 PM
Joined Jun 2014
this is very good thank to all
Old Sep 15, 2014, 08:53 PM
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
You want a vector image to scale, not a raster. Scaling in PS scales line weights, and can result in some pretty wonky lines. If you can get a Vector file, that's best, as the line weight can stay the same but the dimensions will change.
Mark
mrittinger is offline Find More Posts by mrittinger
Old Sep 16, 2014, 01:45 AM
Roguedog's Avatar
Joined Feb 2007
What you say is true. The problem is that I don't even think the Current RCMplans facility has the original prints let alone a vector file.
Of the five plans I purchased, when it was RCMMagazine.com before the change to RCMplans.com, 4 seemed like they were made from a copy, not a copy from the original mask, vellum, blueprint, cad file, or vector file. All had wavy lines like the master had shrank in several places. Now you could say that maybe the copy I got shrank in transit. Could be.
I can say this, even the plans I purchased had thick lines and of the plans that I enlarged through PS the plans I enlarged were not any thicker than those I bought.
I do know that if you use the scanning software to enlarge a plan that it makes some seriously fat lines.
It all depends on how you use the tools at you're disposal and of course if you had it in a vector format scaling would be a cinch.
Question How can I scale up/down paper building plans? Stonefly Electric Plane Talk 45 Dec 28, 2013 11:45 AM
Discussion Do plans scale up without modification? cloud_9 The Builders Workshop 19 Nov 20, 2013 10:22 AM
Discussion How hard would it be to scale down 1/4 scale plans? newkid Scale Kit/Scratch Built 2 May 14, 2006 07:18 PM
Up....down....up.....down......up....down. losinground Electric Heli Talk 24 Oct 25, 2004 11:15 PM
Scaling plans up or down? Balin Sport Planes 5 Mar 10, 2002 05:36 PM
