Old Apr 18, 2014, 03:36 PM
Joined Aug 2013
Simple question on reversing an ESC
I am in the middle of my first quad build right now.
I am using the HobbyKing Blue series ESC. The programmer has an option to reverse direction. Is that ok to do, vs changing the wires.
The wires are hidden and it will save me a lot of time if I can just program the ESC.
robin
RobinBones is offline Find More Posts by RobinBones
Old Apr 18, 2014, 04:04 PM
Condescending Pedant
Joined Aug 2013
It will be fine to do it through ESC configuration. I have seen some people recommend against using the ESC configuration because if the ESC somehow gets reset to defaults, the motor will run in the wrong direction. So if that happens just reverse it again.
Mike Dubovsky is online now Find More Posts by Mike Dubovsky
Discussion Question on HV ESC Sovrin Electric Ducted Fan Jet Talk 4 Nov 29, 2013 12:02 AM
Discussion An ESC related question and differents simonk firmwares jaas75 Multirotor Electronics 2 Nov 15, 2013 06:37 PM
Question How do I figure out the amp rating on an ESC that's no longer labelled? Peejster Castle Creations 1 Oct 07, 2013 05:05 PM
Discussion Question on ESC or Controller Calibration RobinBones Electric Plane Talk 6 Sep 20, 2013 02:11 PM
Discussion Question about a GWS 5A ESC on an SS TheDustyPagan Power Systems 4 Dec 12, 2006 12:37 PM
