Old Mar 06, 2014, 10:38 PM
Joined Mar 2014
hi. im new here. and need help to reverse GWS s36/std servo
hi..
does anyone know how to reverse the GWS s35/std motor using pic16f877a??
here's my code
device = 16f877a
trisb = 0
main:
pulsout portb.0,300 ----> seem's working in this code for forward
pulsout portb.1,100---> this one is not working for the reverse..
kindly help me..
this is for our project study..
thank you somuch.
and more power.
picbot is offline Find More Posts by picbot
Old Mar 06, 2014, 10:44 PM
Joined Mar 2014
i mean GWS S35/std servo motor..
Old Mar 09, 2014, 09:45 PM
Taipei, Taiwan
Joined Oct 2005
Hi Picbot,
Normally we refer to PWM for controlling GWS servos including this mentioned S35/STD. That is 1.5 ms or 1500 μs meant for its neutral position, while PWM signles less than 1.5 ms make it turn left continuously, while more than 1.5 ms turn right continuously.
There are two ways for changing its rotating directions:
1. Switch the leads on the motor at the inside of this servo, but this way is NOT recommended by GWS. YOu have to take your own risks if you'd like to do so.
2. Switch the direction that you fix the servo on your device. ie, if the servo arm was at the right end, pull the entire servo off your device, turn it around, make the servo arm at the left end, then fix the servo on your device. Putting the servo upside down is another way to go if you do not mind it.
Hope this could be helpful.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Discussion i am new and i need help for programming of GWS servo motor S35/STD. need to reverse picbot Robotics 0 Mar 06, 2014 10:05 PM
Help! im new with driving so i need help? nitro. user101 Nitro and Glow Power Cars 13 Dec 02, 2013 05:06 PM
Discussion Help needed with GWS MINI STD servo dvsvkimo GWS (Grand Wing Servo) 1 Mar 27, 2009 10:05 PM
Rave Hi Im new here and need help Please roundthebend Micro Helis 11 Aug 01, 2005 02:20 PM
