Old Oct 17, 2013, 07:52 AM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Specs for 30''-32'' KFm2 FPV wing?
Hey guys,
Just looking for some specs on a FPV wing 30-32 inch? It needs to be able to carry light FPV gear and a 2200mah battery.
-Ben
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Old Oct 17, 2013, 12:09 PM
buyer of the farm
United States, FL, DeLand
Joined Mar 2009
That's a bit small for FPV use. You'd be much better served with at least 48" wingspan.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Oct 18, 2013, 10:56 AM
United States, WA, Moses Lake
Joined Feb 2012
Why are you needing it to be 30-32 inches? With that big a battery and radio gear I think it would be really hard to launch. Look around most fpv rigs are bigger than that. Maybe you could launch it with a catapult rig or bungee launch it though.
Low and Slow is offline Find More Posts by Low and Slow
Old Oct 18, 2013, 07:23 PM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
This could easily be adapted to kfm2: http://www.rcgroups.com/forums/showthread.php?t=1040837
Granted is online now Find More Posts by Granted
Old Oct 18, 2013, 10:29 PM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
I can only get foam that size I think i'll go with the the micro zephyer that RCTESTFLIGHT made.
Mini Zephyr 3 - RCTESTFLIGHT (3 min 54 sec)
-Ben
Old Oct 19, 2013, 08:34 AM
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Don't limit yourself by the width of your foamboard. You're building a layered wing, so join sheets and stagger the seams for a wider span.
This is a 40" kfm4 3-sheet $tree foam paper-off wing with 15" root, 12" tip and 12" sweep. It weighs 615g AUW with a 2200 3s and floats around for 30 minutes with a 2208-1260kv spinning a 8045sf prop.
This was my favorite wing till I started hotwiring and it still sees regular use. The top and bottom layers are seamed in the center and the middle layer has seams 5" from each tip and doesn't require tiled plans, just measurements around the perimeter of your foamboard and some straight lines connecting them.
Build Log Easy 30" KFm2 Delta mnemennth Foamies (Scratchbuilt) 1 Jan 04, 2014 04:23 PM
Build Log Mini Predator Drone - 1mtr wing span, KFm2 (new video) Arxangel Foamies (Scratchbuilt) 41 Jul 25, 2013 07:40 AM
Discussion R.I.P Did I make my kfm2 wing too heavy? sgrouts Flying Wings 7 Jul 19, 2013 11:42 AM
Old but unused raptor 30, Looking for FPV wing sprokus Non R/C Items (FS/W) 0 Jan 27, 2013 11:45 PM
Discussion FPV AP Pusher UGGLAN UAV with KFm2-wing Continued jjr2001 Aerial Photography 11 Oct 19, 2010 02:06 AM
