Old Apr 24, 2011, 06:15 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Question
800 mah 11.1v 3 cell battery with a 7.4 motor?
I have a Motor from Art-tech and it the only thing it says on it is "7.4 volts".
I have the battery that came with it but not the charger. The battery that came with it is 7.4 volts 1400mah. The battery I would like to use is 800mah and 11.1v. Will this work? The esc is a 20a brushless motor esc.
bakon is offline Find More Posts by bakon
Old Apr 24, 2011, 06:25 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Also a quick reply would be very much appreciated. i would like to fly today.
Bakon
Old Apr 24, 2011, 06:47 PM
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
sure, for some time it will boost the motor to turbo mode, then the overload might fry the motor, the fried motor might maje the esc let out some fancy color smoke, after this, the battery pack says goodbye in flames
Or i might underestimate the durability of the 7.4V motor you are using, and you may get less than 40% flight time at some insane speed compared to the original 2s setup.
Z
z-matrix is offline Find More Posts by z-matrix
Old Apr 24, 2011, 08:40 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Z
Thanks for the reply. I have scrapped that plane and I am using the motor and electronics for a jet, but I have one more question. If I were to use a 2 cell 800mah would the motor fry the battery?
Old Apr 24, 2011, 10:26 PM
Joensuu, Finland
Joined Mar 2002
Originally Posted by bakon View Post
...If I were to use a 2 cell 800mah would the motor fry the battery?
That would depend on battery C-rating and how much current the motor actually draws. The biggest factors determining amp draw are propeller size and motor kI-value. So we don't have enough data to answer your question. When making any changes to the power train you should measure amps and volts to confirm that you are still within every component's specification.
jkettu is offline Find More Posts by jkettu
Old Apr 25, 2011, 06:24 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
Well I just found out that it is a 970kv motor.
Old Apr 25, 2011, 10:01 PM
Joensuu, Finland
Joined Mar 2002
Sorry, but that doesn't help answering your question.
How many amps does the motor draw on 2s? (Get a wattmeter asap if you don't already have one)
What is the C-rating of your 2S 800mAh battery?
Old Apr 25, 2011, 10:03 PM
I Toast Planes
bakon's Avatar
Joined Jul 2010
I will get one asap. Thanks
Discussion Need a power plug for E-fly 11.1v 1800 mAh battery bltefft Batteries and Chargers 4 Mar 27, 2011 01:22 AM
For Sale (3) 1800 Mah 15C 11.1V Batteries RCSwitz18 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 06, 2011 10:09 AM
For Sale Thunder Power Pro-Lite TP 1320 mAh 3 cell 11.1V and 2 cell 7.4V LiPo Battery TP taps shschon Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 13, 2008 10:06 AM
For Sale Thunder Power Pro-Lite TP 1320 mAh 3 cell 11.1V and 2 cell 7.4V LiPo Battery TP taps shschon Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 11, 2008 06:32 PM
Sold ThunderPower 730 mAh/2S 7.4V, and Hyperion 800 mAh/3S 11.1V rivers Aircraft - Electric - Batteries & Chargers (FS/W) 4 Nov 09, 2008 07:15 AM
