Old Feb 23, 2014, 06:05 PM
mooredge is offline
Find More Posts by mooredge
United States, CA, Sacramento
Joined Apr 2008
Frsky loss of signal - Please help
Please help me figure out whats going on here.
Was flying my homebuilt f450 quadcopter FPV today and had a signal loss about 50m out and it tumbled out of the sky. As I was flying it at about 100m out and 50m up it Frsky module started beeping at me, quad started acting squirrly so I attempted to pilot it back. Got it close to regaining controll then about 50m out complete signal loss and I watched it tumble out of the sky FPV. Terrible thing to see. 3 broken props and 1 broken arm later I'm so frusterated.
Setup is the following.
F450 quad with kk 2.1 controller.
2.4 Ghz Turnigy 9xr with Frsky DJT module and D8R-II plus reciever.
Fat shark Attitude V2 setup 5.8 Ghz with everything pretty much stock.
After retrieve the wreckage battery voltage on my 3s 2600mah lip was fine at 11.6 ish. Tx battery voltage was ok as well
Background. I've had the Frsky setup on this quad without FPV for the last several months with no issues, I have flown it LOS probably to about 150-200m. Recently I added the FPV setup. Since I started flying the FPV i noticed the Frsky module lately has started beeping at me when i get about 100m out which seems ridiculous. Before adding the FPV setup this did not occur. The other thing i noticed just a few days ago was the antenna on the Frsky module was a bit loose. I tightened it up and didn't think much of it.
I'm wondering if it is the antenna on the 5.8 Ghz VTx that is messing things up or something is wrong with the Frsky module.
I'm relatively new to this hobby so any help is greatly appreciated.
mooredge is offline Find More Posts by mooredge
Help! NAZA + GPS Failsafe RTH when signal loss (FrSKY) Peter1987 Multirotor Electronics 2 Jun 11, 2014 04:48 PM
Help! Frsky loss of signal - Help please mooredge Radios 3 Feb 23, 2014 11:09 PM
Discussion Loss in signal HELP!!!! ggradtech Electric Plane Talk 23 Oct 08, 2013 09:17 PM
Discussion Naza v1 (with v2 firmware) won't go into failsafe on loss of signal Troiano27 Multirotor Electronics 1 Sep 25, 2013 12:45 PM
Discussion FrSky DHT-U Loss of signal Norsehammer Radios 2 Jan 13, 2013 12:09 AM
