Old Feb 26, 2004, 03:36 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
Astroflight Firefly
What is the best prop to use with the Astroflight Firefly (brushless), and what typically would be the size and weight of the plane this would successfully power?
foamflyer is offline Find More Posts by foamflyer
Old Feb 26, 2004, 03:53 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
1) The Firefly isn't brushless- it's coreless.
2) Depends on the gearing and the prop. With the 4:1 gearing, I think a 5" prop is typical, with the 16:1 gearing- a 9" prop is closer to it.
3) Airplanes very close to rubber power- this is typically about a 10 watt motor, and probably has less power than an IPS. It's lighter and uses much lighter batteries as well though.
I'm currently building an airplane (Antoinette- not the Sig kit) for the 16:1 motor.
Like a lot of Astro Bob's smaller stuff, these motors really like li-poly as opposed to nickel cells.
Megowcoupe is offline Find More Posts by Megowcoupe
FS Astroflight Firefly and ESC LarryFlew Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2002 06:05 PM
AstroFlight FIREFLY coreless motor w/ 16:1 gearbox Flying Cat Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2002 08:46 PM
AstroFlight Firefly Motor rplourdejr Parkflyers 5 Mar 06, 2002 03:59 PM
Possible Astroflight Firefly 4:1 applications? nolasco Parkflyers 5 Oct 07, 2001 04:20 PM
Astroflight Firefly Motor nolasco Parkflyers 1 Jun 29, 2001 01:24 AM
