Old Sep 14, 2013, 01:57 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
10/32 isn't a proper fraction, 5/16 is
derk is offline Find More Posts by derk
Old Sep 14, 2013, 04:02 AM
Diggi's Avatar
Joined Oct 2012
You never stop learning!
Diggi is offline Find More Posts by Diggi
Old Oct 21, 2013, 06:54 AM
United Kingdom, Melksham
Joined Sep 2013
Newbie!
These planes are incredible. I have a larger dlg but am now starting to work no a micro based on micro builders awesome single aileron glider. My wing is coming on nicely given my lack of skill but the electrics are somewhat confusing.
I am looking at picking up a cheap micro reciever (http://www.ebay.co.uk/itm/Orange-4Ch...item27c6286be8)
but am unsure how I connect a 1s lipo to it to power the system. Do i need an esc?
Can anybody advise me on the best way - is it as simple as putting a connecter on the battery that fits directly into the receiver? and if so what would the connecter be called?
Thanks in advance
neiltmorris is offline Find More Posts by neiltmorris
Old Oct 21, 2013, 09:27 AM
Joined Sep 2013
Originally Posted by Diggi View Post
Yes, of course I can. Takes a day or two to rework my drawing.
For now:
About 690 mm wingspan (sorry for the mm and for my bad english, I'm from germany)
10 dihedral each side
about 90 mm root chord
trailing edge to elevator ~ 270 mm
elevator: 160 / 50 mm
Boom is a cheap 5 mm cf pultruded tube from the kite shop.
I like the idea of screwing the wing to the boom and to be able
to experiment with different wings or the angle of attack, so that's why.
Spring and fishing line
Rx: Graupner GR-12-SC+ (similar to the AR6300)
Two HK5320
120 mAh LiPo
It's obvious, that I followed Yasu's blogs, but my glider seems to be a miserable copy.
Best regards
Dirk
Hi, what an amazing plane!
I am just starting on my first build and have almost the same electrics as you spare to use on it. How do you connect a 1s lipo to the receiver? it only has sockets for aileron, elevator, throttle and rudder.
here is a link to the receiver if it helps? any advice would be brilliant!
Old Oct 22, 2013, 12:09 AM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
The battery will plug directly into any socket on the receiver, negative to the outside pin.
At these spans a brick would be a lot lighter and probably easier and cheaper.
Rusty Nail is online now Find More Posts by Rusty Nail
Old Oct 25, 2013, 10:07 AM
Mattfly's Avatar
Champaign. Illinois
Joined Jun 2003
Here is my scratch built HLG from JR indoor last year.I plan on bringing it this year along with my 700mm "nice" one.
The one in the video is all balsa with a fiberglass fishing pole for the tail boom. Uses Parkzone brick and a 150mAh battery.
JR indoor DLG (1 min 11 sec)
Matt Andren
Horizon Hobby
Mattfly is offline Find More Posts by Mattfly
Site Sponsor
Old Oct 25, 2013, 12:11 PM
Diggi's Avatar
Joined Oct 2012
Cool! And smooth flying ...
Old Oct 26, 2013, 12:18 PM
Joined Sep 2013
Thanks rusty
Brilliant, thanks for the help rusty. New to this but already found so many helpful people.
Nice glider matt! Starting my own dlg inspired by microbuilder and yasu, with most help coming from rc groups!
Old Nov 12, 2013, 04:01 PM
Joined Jun 2012
New 1 m DLG
Hello every one, hor are you? this is my third DLG, in this case 1 m and a copy of the Elf...king of, because this one has alerons !!!
lagarto is offline Find More Posts by lagarto
Micro Hlg ???????? AIR MOVER Hand Launch 14 Aug 04, 2009 09:28 PM
bug micro hlg f/s ERGO60SX Aircraft - Electric - Airplanes (FS/W) 8 Nov 27, 2002 09:01 PM
Micro HLG Conversion Q's RB Scratchbuilt Indoor and Micro Models 1 Nov 10, 2002 09:44 PM
Anyone Fly the DAW Dragonette Micro HLG??? webguyjv Electric Sailplanes 9 Feb 20, 2002 12:44 AM
Albatoss micro HLG? cheapflyr Electric Sailplanes 6 May 26, 2001 11:52 AM
