Old Apr 21, 2007, 12:08 AM
henrykk's Avatar
Australia, VIC, Surrey Hills
Joined Jun 2006
1:3 Std cirrus build
Hi all,
I'm just working out all of the components of fuse/cores build of a 1:3 Std cirrus. (I will add photos as I go)
I am looking for innovative way of making a direct drive rudder from a servo that mounts in the fin. There are no flanges for a pull-pull style setup so the drive must be internal.
Any suggestions/links/images would be welcome
ta
Henryk
henrykk is offline Find More Posts by henrykk
Site Sponsor
Old Apr 21, 2007, 06:24 AM
I failed linkage geometry
salisbug's Avatar
Melbourne, Australia
Joined Jun 2002
G'day Henryk,
I know the sort of arrangement your looking for but cannot find the photos.
It was posted on the group here in the last 6-8 months or so. I know this because I'm fairly new to scale and the concept fascinated me with its simplicity.
The rudder servo is mounted on a small tray the width of the fin. It is mounted to the rudder L/E using small pushrods either side in a pull-pull arrangement.
The tray is located into channels in the fin created by wood strips glued to the internal fin sides so the tray just slides in and is not secured as such to the fin, but the rudder hinge locks the whole unit in place.
salisbug is offline Find More Posts by salisbug
Big Nuts 181's Avatar
Joined Jul 2004
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Apr 21, 2007, 08:35 AM
henrykk's Avatar
Joined Jun 2006
Hey G,
is this what you were talking about?
http://www.soaringissa.org/tech_tips...er_install.htm
Site Sponsor
Old Apr 21, 2007, 11:42 PM
salisbug's Avatar
Joined Jun 2002
That's the one. Simple & very clever.
Old Apr 23, 2007, 09:57 AM
Perth, Western Australia.
Joined Apr 2007
Henrykk,
The Standard Cirrus has the rudder side hinged from the starboard side of the fin and the rudder horn is internal. Which model Standard Cirrus are you intending to build?- the early model blunt nose Cirrus - the pointed nose Cirrus 75 or the Cirrus VTC from Yugoslavia.
I own and fly a scale 1:1 Cirrus 75 and I can provide you with scale details if you so desire.
wedgetail is offline Find More Posts by wedgetail
Old Apr 23, 2007, 03:13 PM
Lunns's Avatar
Joined Aug 2003
Henryk,
Attached are photos of how the rudder is setup in my micro swift, the rudder is live hinged to the starboard side and internally the pushrod is internally connected to the inboard port side of the rudder.
Cheers
Steve
Lunns is online now Find More Posts by Lunns
Old Apr 23, 2007, 06:12 PM
henrykk's Avatar
Joined Jun 2006
Hi Guys - yes the blunt nose early version (built by SH) with the all moving t tail. The rudder is a very interesting detail that I did not know. I had assumed that it was centre hinged - Wedgetail - the images I have of the one in Bachus Marsh looks like it is centre hinged in the photos - I cannot find any documentation to the contrary.
I'd love a set of shots of your glider - if nothing else - to add it to the scale documentation part of my website:
http://www.silentflight.net/
some history of that particular sailplane would be great as well. PM me and I will give you any details you need.
rgs
Henryk
Site Sponsor
Old Apr 23, 2007, 07:27 PM
Shhhhh
Roachie's Avatar
Armidale NSW Australia
Joined Jan 2006
I was wondering what the little brass thing was for....I just drilled a smal hole in the rudder and put a zeebend on the control wire.....very neat and no glueing
Did you get a manual with yours?
Originally Posted by Lunns
Henryk,
Cheers
Steve
Roachie is online now Find More Posts by Roachie
Old Feb 09, 2008, 05:53 PM
Joined Jan 2005
Dear Henryk
what's going on with your cirrus?
A little bit late but maybe also helpful for others.
For Cirrus details have a look on:
http://www.standardcirrus.org/
For the tail wing
http://www.standardcirrus.org/Elevator.html
For ruder navigate to
http://www.standardcirrus.org/WU-Stabilizer-2.jpg
or to
http://www.standardcirrus.org/Specifications.html
It's true ... the ruder is hinged on the right side.
You can find a detailed picture of the one I have flown about 200h on the following site:
http://www.stierlen1.homepage.t-onli.../CAD/ruder.jpg
The small hole is for the socket wrench which you need to hold the screw if you want to disassamble the linkage.
Please put some pictures of your cirrus on the web.
rgs
Peter
peter_stierlen is offline Find More Posts by peter_stierlen
Old Feb 09, 2008, 09:15 PM
glider guider
glider guider's Avatar
Winnipeg, MB
Joined Mar 2005
Here is another rudder drive thread.
http://www.rcgroups.com/forums/showthread.php?t=771305
glider guider is offline Find More Posts by glider guider
Old Feb 10, 2008, 03:18 AM
Hi Henryk,
I believe the Cirrus you are working on is the one I sold to Col Collyer a few years ago, Bit of a coincedence that, as I have just resently aquired its sister and am about to get stuck in to building the tail surfaces really soon, My plan for the rudder is to mount the rudder servo into the rudder post and as somebody else here mentioned, because it is a side hinged surface just run a short pushrod to the right side of the rudders leading edge.
I'm planning also to put the elevator servo inside the tailplane as far forward as possible and use it as the mass balance, doing it this way will also make it easier to make the fairing that moves with the tailplane more scale.
Good luck with yours I'll post a picture or two of mine as it progress's along the way.
regards,
Alexis
Hamish . S is offline Find More Posts by Hamish . S
Old Feb 10, 2008, 03:31 AM
Joined Jul 2004
Old Feb 10, 2008, 04:03 PM
I believe they are all side hinged, I just remembered that at, standardcirrus.org there is a picture of a rudder with it hinged wide open to show the rudder post etc, I'll try to post alink here later,
regards,
Alexis
Old Feb 13, 2008, 02:28 PM
henrykk's Avatar
Joined Jun 2006
Hi Alexis,
Thanks for asking - but I have had some big delays over the past few months with moving house and having to set up new workshops etc. I have just managed to get the lab finished and starting to work on the cirrus again. hope to see some progress over the next few weeks.
Site Sponsor
Build Log 1:3.5 Scale Skylark 4 Build chris williams Scale Sailplanes 64 Dec 23, 2009 02:07 PM
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
New Version of WebWeather (1.3) eladyland Parkflyers 12 Jul 27, 2003 06:12 PM
Zagi C/G 8 1/3, is it flyable? Tompa Foamies (Kits) 4 Apr 27, 2002 01:31 PM
ModelTech 1/3 Scale Cub mkirsch1 Sport Planes 2 Dec 16, 2001 04:24 PM
