Old Mar 21, 2007, 11:24 PM
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Help!
I hope my rep can handle one dumb question!
Ok.
I have a battery pack that is 4.8v 160mAh NiMh
Ok.
I would like to add 2 more cells but they are 4.8v 150mAh
So with this new pack will my charger and car except it ok? Or will I wreck the battery, charger, or the car?
I know I need a beginning electronic class so that doesn't need to be mentioned!
But if it helps I trust this group over all others, and that means something!
This idea is a temp solution until the pack I want to buy is in stock.
thanks,
James
Butters is offline Find More Posts by Butters
Old Mar 21, 2007, 11:34 PM
Bruce
Palmdale, CA
Joined Sep 2005
If it is really 160 and 150 mAh it doesn't have enough capacity to move a HOR more than a few feet. What size are the cells? Are you sure it isn't 1600 and 1500 mAh?
In general, for maximum performance, you want to match the mAh but if they are close in mAh and you aren't worried about peak performance then you will be fine. NiMH cells are 1.2V so your 4.8v pack plus 2 cells will give 6v.
Bruce
slawsonb is offline Find More Posts by slawsonb
Old Mar 21, 2007, 11:58 PM
Butters's Avatar
Your Mama's house!
Joined Mar 2005
he he I never said it was for a HOR. And yeah it's 150 mAh and 160 mAh.
It's for a Micro T.
But thanks for the reply Bruce, I'm going to do it.
Old Mar 22, 2007, 07:43 AM
Beat it till it breaks.
Mentalmadness's Avatar
N.W.Ohio
Joined Oct 2006
They do make a lipo for those already if you didnt know. Not sure if that is the direction you wanna go but just wanted to let you know.
As far as the stock charger be able to charge them......It should but will just take forever.
Mentalmadness is offline Find More Posts by Mentalmadness
Old Mar 22, 2007, 08:39 AM
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Cool thanks. And yeah I know about the lipo pack from Losi it also comes with a charger for about $50.00 bucks. That is what I'm waiting for but it won't be released until mid April, Bummer.
And I know, I can always go get another kinda of lipo, the forums are full of people buying this and that, and craming them in but I would need a power source and charger, and that is more then what I want to spend.
Old Mar 22, 2007, 02:09 PM
N.W.Ohio
Joined Oct 2006
Yea I know all about that. I am setup great for nicd and nimh but i would have to change alot of things to run lipo.
Old Mar 22, 2007, 02:36 PM
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Amen!
Old Mar 22, 2007, 06:48 PM
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Ok. I did it. But then as I was operationing I figured why stop with 2? I did all four! It was actually easier then braking apart the little pack for just 2.
Now my pack is 7.2 volt, PERFECT. Cause I also have a brushless motor and a Tekin speed control so, I think I will fly! I hope.
We will see.
Discussion I hope this isn't a dumb question hulrich Coaxial Helicopters 7 Feb 12, 2007 09:08 PM
Question Where else can I get one of these for my Shogun V2? nieves50 Mini Helis 1 Feb 13, 2006 11:53 AM
Drat! my LHS is Backordered on the Slowsticks - Anybody know where I can get one? mrebman Parkflyers 3 Nov 25, 2002 08:54 PM
