Old Jun 14, 2001, 10:06 PM
Joined May 2001
5.5 x 5.5 Folder Prop?
Does anyone know where to find a 5.5 x 5.5 folding prop? Planes just don't like to land on the Cam 5.5 - they break or break your plane. The Cam 5.5 is a great prop, it would be even better as a folder with a 1-3/16" dia. spinner.
Keith W is offline Find More Posts by Keith W
Old Jun 15, 2001, 09:11 AM
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
David Fee may chip in here, he made some sample 5x5 folders that were closer to 5.5x5.5.
BTW what motor are you using the 5.5x5.5 props on?
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Jun 15, 2001, 07:12 PM
Palo Alto, CA, USA
Joined Nov 2000
APC now makes 5x5 and 6x3 folders. The hub comes in different widths, starting with 35mm. I am running the 35mm hub with the 6x3 blades on AF 010 at ~13000 RPM. I can't remember what is the max RPM rating.
kasra is offline Find More Posts by kasra
Old Jun 15, 2001, 08:26 PM
Joined May 2001
Thank you both, I think I will look into the APC's - (easily available). I am running a Kontronik BL400-22 12,800 rpm on 7 cell 600AE's 5.5x5.5 Cam prop.
Old Jun 17, 2001, 12:28 AM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Try the CAM 5 x5 or the 6x 5.5. APC does not work well on low rpm. The 12800 is low rpm. My sp400 with 4.7 x 4.7 spins at 15600. The APC does not performs as well as the Grauper CAM at lower rpm.
Try the Graupner 6 x 5.5.
Brian
bhchan is offline Find More Posts by bhchan
Old Jun 18, 2001, 02:54 PM
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Hi Keith...
Sorry it took me so long to chime in... I've not been home much lately. Anyway, yes... I did start molding some carbon folders based on a 5x5 CAM prop, but they ended up being probably more like 5.5x5.5, as Neil correctly stated. As a result, they're maybe a bit too much prop for a S400, but they might be ok for your brushless motor, if you had an appropriate hub. Links are below...
Good luck and have fun!
David
<a href="http://www.members.home.net/davidfee/PROJ.html"> <IMG SRC=http://www.members.home.net/davidfee/images/s_propopen_s.jpg width="108" height="60" border="0"></a> http://www.members.home.net/davidfee/PROJ.html
davidfee is offline Find More Posts by davidfee
Sold *** Aeronaut 18.5 x 12 Cam Carbon Folder Prop NIP *** Rudderman98 Aircraft - Sailplanes (FS/W) 4 Jul 25, 2006 10:58 PM
Brushed Astro 40G with 13.5 X 13.5 prop. Help!! gbruce Power Systems 4 Oct 19, 2005 09:25 PM
Himaxx 2515-4100 + 5 x 2.5 prop on 3 cell lipos possible? tnsfrk Power Systems 11 Oct 29, 2004 12:26 AM
Where to buy a 6.5 x 3.5 prop? Cubby Boy Power Systems 3 Jun 25, 2003 06:02 PM
Wedgie with MA 5.5 x 4.5 Prop mario alvarez Foamies (Kits) 6 Aug 19, 2002 10:08 PM
