Old Mar 02, 2014, 01:52 PM
mchopper's Avatar
Joined Mar 2014
Help!
corsair retracts problem
Hi all just joined this forum,
straight in with this one,
got a dynam corsair and took it for a maiden today but on landing approach hit the gear switch to lower landing and nothing! panic set I. and tried it a couple more times and eventually they lowered. on the ground tried the gear and they just would not lower the only way they would work was if I have the ailerons a wiggle on the stick. tried all the usual things connections end points took one of the retracts out and tried again and same problem
just tried them at home and they are working as they should maybe it was the cold weather or something.
anyone else had this iusse?
thanks
matt
mchopper is offline Find More Posts by mchopper
Old Mar 02, 2014, 02:37 PM
Joined Dec 2009
To save confusion
.....I would suggest you post your enquiry in the main Dyman Corsair thread, rather than start another:-
http://www.rcgroups.com/forums/showt...=dynam+corsair
Plane Chaos is offline Find More Posts by Plane Chaos
Old Mar 02, 2014, 04:55 PM
mchopper's Avatar
Joined Mar 2014
brill thanks for the link
Discussion Parkzone f4u-1a corsair takeoff problems!! 8KDR22 Electric Warbirds 12 Nov 25, 2013 04:26 PM
Wanted Corsair retracts JETmachine Aircraft - General - Miscellaneous (FS/W) 1 Nov 11, 2013 04:21 PM
Sold Parkzone Corsair never flown w/retracts s2000 Aircraft - Electric - Airplanes (FS/W) 5 Oct 16, 2013 08:18 PM
Sold 5-CH AirField1430mm F4U Corsair ARF w/ Motor/ESC/Retracts $100 Winterdd Aircraft - Electric - Airplanes (FS/W) 2 Oct 09, 2013 12:55 PM
Sold Top flite .60 corsair with e-flite rotating retracts chandley Aircraft - Fuel - Airplanes (FS/W) 4 Oct 08, 2013 10:23 AM
