Old Jan 23, 2014, 05:47 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
JR DSX9 left 3 posistion switch reversed
Hi
I'm programming in sailplane mode and my left 3 pos seitch is reversed.
1. Land is the up pos (0)
2. Launch Is in the down pos(2)
In acro mode the switch functions normally.
Any ideas how to change this?
justy g is offline Find More Posts by justy g
Old Jan 23, 2014, 08:44 PM
USA, FL, Milton
Joined Jul 2008
In the JR 9303 the reversing of the Launch mode switch is done in the Device Select Menu. On the left side of the screen under "Launch" there is an icon titled either NOR or REV. Roll over it and click the selector and the title will change. This will reset the ON side of the Launch switch opposite to what it was.
Don't know if the DSX9 has the same function but it seems logical that it would. My JR XG11 carries it over. Works the same way.
Hope this helps.
lc
liftchaser is online now Find More Posts by liftchaser
Old Jan 23, 2014, 10:19 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
Thanks for the reply.
Unfortunately, when I device select there is no normal/reverse option for launch. It just shows inh and the switch options.
The programming I believe, is the same as the PCM9X II, that's the manual I have for the TX.
Still scratching my head over this one...
Old Jan 24, 2014, 12:22 AM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Justy,
The programming of the DX9 is almost identical to the DX18. If you go to the Spektrum RC website, you can download the setup that is on there by Sherman Knight. You down load to your SD card, put it back into the DX9 and copy the file. Works nice.
Mike Lee
mlee8249 is offline Find More Posts by mlee8249
Old Jan 24, 2014, 01:27 AM
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
Chase the lift
Justy,
See my reply on the radio thread. I think Liftchaser has the answer and you may not have rolled quite far enough (though it is also possible that your DSX9 has different programming, earlier or later, than mine).
Cheers,
PeteM
Petem is online now Find More Posts by Petem
Old Jan 24, 2014, 10:21 AM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
You can switch the locations of switches A and I and then use switch I as the launch switch.
davidjensen is online now Find More Posts by davidjensen
Old Jan 24, 2014, 04:15 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
Thanks for all the replies.
1. I have no normal/reverse in device select.
I contacted the UK-importer Macgregor and here's their response
"Dear Sir
Unfortunately this is an error in the manual and this cannot be reversed.
Kind regards"
Here's the screen shot
I have tried switching between f/mod switch and 3 pos and are both reversed. No SD card on this radio as it's an early JR 2.4ghz not a Spektrum.
So I will just have to live with it being reversed
Old Jan 24, 2014, 04:26 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
Originally Posted by mlee8249 View Post
Justy,
Mike Lee
This a JR radio not a Spektrum
Old Jan 25, 2014, 01:07 AM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Wow, Justy, my bad....I was seeing DSX9 and thinking DX9. Better have them reading glasses checked! Thank you for pointing that out.
I'll just crawl off to my happy place, now, and find some drugs.
Old Jan 25, 2014, 01:33 AM
justy g's Avatar
Hong Kong
Joined Jan 2007
Easy mistake..
Discussion JR DSX9 3 3 position flap switch reversed justy g Radios 6 Jan 24, 2014 01:22 AM
For Sale JR Plastic Carry Case For JR 9X,DSX9 Alwayscrash Aircraft - General - Radio Equipment (FS/W) 0 Dec 06, 2013 10:12 PM
Help! Broken Switches on JR DSX9 V2 mahbouni Radios 7 Dec 09, 2012 11:38 AM
Discussion JR PCM9XII/DSX9/X9303 - Automatic switching of timer by throttle stick yogi100 Radios 16 Oct 04, 2010 02:55 PM
Discussion jr dsx9 butterfly on switch biojay Radios 0 May 17, 2009 07:52 AM
