Old Feb 23, 2013, 03:08 PM
Joined Feb 2013
Help!
Removing Glued in Servo
I have currently purchased a used Reef Racer 2 with a brushless converion. I did not do the conversion myself so there is some work I dont like including the servo. The servo stopped working and I need to remove and replace it. I am new to RC boats and I don not know any ways to remove it. PLEASE HELP! Thanks
taylchad is offline Find More Posts by taylchad
Old Feb 24, 2013, 01:14 AM
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
Sometimes I will pick at the glue and try to work the servo loose . Or you could just tear it out seeing that it is junk anyway .
jmolwitz is offline Find More Posts by jmolwitz
Old Feb 28, 2013, 12:22 AM
United States, FL, Fort Walton Beach
Joined Jan 2013
glued in servo
have you considered unscrewing the four top screws, and yanking out the guts, leaving the bottom of the servo box still embedded. Buy the same model servo, yank the top and guts and put them into the old servo bottom. They're the same servo, the parts should be the same. Assuming of course you can find a new duplicate matching servo. I hope the servo is a name brand
Craig
sorcerercraig is offline Find More Posts by sorcerercraig
Discussion Gluing in Servos for Ease of Removal Later roo_ster Electric Plane Talk 18 Dec 05, 2011 05:52 PM
Help! Removal of Hot glued servos? Jcopter Electric Ducted Fan Jet Talk 13 Apr 11, 2010 07:44 PM
Help! How Do I Remove Hot-Glued Servo From Foam Wing? nolebotic Foamies (Kits) 10 Dec 27, 2009 11:40 AM
Mini-HowTo Removing glued in pushrod tubes jcpatrick The Builders Workshop 2 May 10, 2009 10:17 PM
For Sale custom servo screw wrench, for glued in servos dhauch Aircraft - Sailplanes (FS/W) 3 Nov 05, 2008 05:52 PM
