Old Nov 12, 2012, 10:14 AM
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
.049 Fuel
Hello all,
I have a Testor's McCoy .049 that I restored back in the spring (link to restoration). I have been wanting to start it ever since but have not had any fuel for it.
What kind of fuel do I need and where can I buy it?
Last time at was at my LHS they said they do not carry 1/2A engine fuel. Can I buy it online, if so where? I may go to the LHS today, if I do what should I look for when buying fuel?
I do have some Nitro fuel for another engine. The sticker on the jug says "2 & 4 cycle. . . .18% oil content. . . .10%Nitro" Would this fuel be fine to try and start the .049 with?
It's probably easy to tell I have never dealt with RC IC engines before.
Thanks in advance,
Nicholas Morgan
P.S. I also posted this in the 1/2A plane forum
PyroMan is offline Find More Posts by PyroMan
Old Nov 12, 2012, 12:25 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
The "real" Testors fuel I believe was 20% or 25% nitro (may be wrong on that) and 25% castor. The Cox engines needed the castor for the ball and socket small end of the con rod. Have you tried Sig for fuel? I know they offer all castor fuel. Not sure if they have small quantities. Maybe Tower also. I know they have fuel in quarts.
Way back in the day I was mixing my own fuel for 1/2A pylon at about 60% nitro. You had to lap the piston and sleeve with tooth paste so the engine would run and not seize.
Ken
kenh3497 is online now Find More Posts by kenh3497
Old Nov 12, 2012, 07:44 PM
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
I think the most important thing with the .049's is having enough oil, and preferably castor, at around 25% although even 20% may be enough. As for nitro, although I've never flown an 049 I've run a few of them (Cox) on the bench using zero nitro and all of them would start with one flick and ran perfectly. Nitro would of course give more revs but it's not necesary.
downunder is offline Find More Posts by downunder
Discussion Cox .049 fuel tank NOI53Y 1/2A Planes 4 Apr 11, 2012 06:57 PM
Discussion How to clamp fuel tubes to a Cox .049 engine arukum17 1/2A Planes 3 Mar 20, 2006 09:32 PM
.049 Supplementary Fuel Tank elaerico Engines 11 May 11, 2005 07:13 PM
Fuel issues for COX 0.049 neniwein 1/2A Planes 9 Mar 06, 2005 05:33 AM
