Old Sep 29, 2012, 09:12 PM
Livin ta fly
sparkx38's Avatar
United States, LA, Shreveport
Joined Apr 2011
Help!
Saito 82 problems
I have a Saito 82 that I am having problems with. It started with a back firing issue. I adjusted the valves with the manufactures feeler gauge. Now its not back firing but It runs really sloppy on the high end. I can not get it to run right above 1/2 throttle. I was running Omega 15% or powermaster 20/20 YS/Saito blend.
Any ideas?
sparkx38 is offline Find More Posts by sparkx38
Old Sep 29, 2012, 09:36 PM
United States, TX, Wichita Falls
Joined Aug 2007
have you checked the timing?
sloan377 is offline Find More Posts by sloan377
Old Sep 29, 2012, 09:39 PM
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Any ideas?
Unless he has dismantled the engine, there shouldn't be a timing issue.
SrTelemaster is online now Find More Posts by SrTelemaster
Old Sep 30, 2012, 06:55 AM
I TOBOR's Avatar
Joined Feb 2007
The High Speed needle is too rich, the valve lash will never have anything to do with kickback/backfiring unless you get them too tight. Dan is correct, the timing is the last thing you should check.
Lean the HS needle at full throttle one click at a time and sneak up on the peak. Leave time between changes for the engine to stabilize, then go another click. When you reach the peak one more click will make it slow down about 50 rpm, go rich one click, that is your peak.
I TOBOR is online now Find More Posts by I TOBOR
Old Oct 02, 2012, 08:55 AM
Joined Aug 2007
sorry, I assumed it had already been apart, my bad. Only time I've ever had one backfire was when I had the gear off a notch or 2 after a rebuild. I failed to read where he had already resolved that.
Old Oct 02, 2012, 09:30 PM
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Thanks guys I'll try that. Will probaly be weekend after this weekend before I get a chance to check it out but will let you know what I come up with.
Old Oct 02, 2012, 09:37 PM
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Whats a good starting point on the needles? Seems like the back firing issue started about the time the engine got broke in so you may be right about HS being to rich. I tried to dial in the high speed needle till I was blue in the face but just could not get it to smooth out. Perhaps I was adjusting to fast and not giving the needle change a chance to show its effects.
Old Oct 03, 2012, 10:10 AM
St Helens, Oregon
Joined Oct 2007
Try a new glow plug.
weswanson is offline Find More Posts by weswanson
Old Oct 13, 2012, 01:04 PM
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Brand new glow plug in it.
Help! Saito 82 idle problem huck1133 Engines 12 Sep 08, 2008 10:42 AM
Help! Saito-82 + Pitts muffler problem, need help!! juvaknin Engines 20 May 09, 2007 11:38 AM
Discussion my saito 82's problem opto3394 Engines 6 Nov 10, 2006 07:42 AM
Help! Saito 82 throttle problems cjneal Engines 19 Nov 06, 2006 09:42 AM
