Old Nov 09, 2015, 09:14 AM
CaliPilot is offline
Find More Posts by CaliPilot
Christian F
CaliPilot's Avatar
United States, MN, St Paul
Joined Mar 2011
Originally Posted by FloBau View Post
Do you use the standard Hitec servo arm?
I have the same setup on the Yak 48" but with the G10 servo arm and there I can hit the elevator.
This is why i asked about the throw used on the Laser.
My question is how much throw is necessary on the Laser?
im using the standard savox arm
CaliPilot is offline Find More Posts by CaliPilot
Old Nov 20, 2015, 09:15 AM
Time Portal is offline
Find More Posts by Time Portal
United States, CA, San Diego County
Joined Mar 2014
Inverted harrier
Hi everyone,
I'm having a bit of trouble getting the 48" Laser EXP into an inverted harrier. Upright harriers are very nice, but for inverted, I find that there's a big range of angle of attack where it gets squirrely and tip-stally.
Skillwise, I've been drilling low inverted harrier figure eights on my Twisted profile foamy for weeks and I'm finally comfortable and confident with the required rudder. But the foamy does spoil me with no tippiness, at any angle of attack.
Is it just getting used to pushing through the full stall and having the nose higher? Certainly I have to push the Laser through this angle range for upright harriers. Maybe I am being too shy on the elevator push for inverted.
C.g. is on the back edge of the bulkhead that is behind the wing tube sleeve. 2814/820, Airboss 45. 4S 2200mah 12x6, 3S 2600mah 14x7 and 13x8. If it matters, Castle 10A BEC, 3x 5070, 1x 5087.
Time Portal is offline Find More Posts by Time Portal
Old Today, 12:34 AM
Doc Austin is offline
Find More Posts by Doc Austin
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You might try a 25% spoileron mix. Works wonders in upright harrier.
I've been running that mix for about a year now on all my planes. I've got it on a switch for when I don't want to run it (precision maneuvers) and it really helps smooth out the harrier flight.
I actually started experimenting with that mix on the plane you see below.
Laser EXP__Epic (5 min 29 sec)
Doc Austin is offline Find More Posts by Doc Austin
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 24, 2014 12:10 AM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 01:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 11:49 PM
