Old Jul 11, 2014, 07:43 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Multiplex EVO update
Multiplex released a firmware update for the Royal EVO transmitters. The new update is v3.50. The have renamed the transmitter from the EVO to the "SX-16". So, when you power up the radio after the update you are greeted with a different screen than what you are use to seeing.
All functions (telemetry, binding, range check, etc.) all work fine with the XtremeLink module. I would expect that unless they update their 2.4GHz module to use some odd protocol, the emulation I did will always work.
JimDrew is offline Find More Posts by JimDrew
Old Jul 22, 2014, 03:10 AM
Joined Oct 2010
Just wondering then; currently using EVO 3.46, do I gain anything by upgrading it to their 3.50, or am I better off just leaving well enough alone using it with your EVO board?
Treeline is offline Find More Posts by Treeline
Old Jul 22, 2014, 10:07 AM
Lake Havasu, AZ
Joined Jun 2005
Well, the name changed to 'SX-16', and apparently there are some other changes to the mixing and such. You can download the changes info from the Multiplex website. I don't see anything obvious other than the name change.
Alert Multiplex Evo 2.4 conversion w/Hitec AFHSS (Digital interface update) MikeMayberry Radios 309 Apr 26, 2014 09:31 PM
Sold for Multiplex EVO\ROYAL Tx: HF-MODUL + Rx (6/7ch) fedor_flyagin Aircraft - General - Radio Equipment (FS/W) 6 Nov 20, 2013 02:21 AM
Discussion multiplex royal evo - expo per phase without update?? mattijs321 Radios 8 Oct 11, 2012 02:08 PM
Discussion Multiplex Evo 9 updated to Pro rgtoth Radios 1 Oct 03, 2009 05:09 PM
Multiplex ROYAL Evo software update modelspot Electric Plane Talk 1 Aug 09, 2003 09:46 AM
